November 27, 200916 yr But you're getting the new tires, radiator, alt... It shouldn't be hard or pricey to locate an engine. Doug
November 27, 200916 yr the 98 forester I'm looking at is listed as having a 2.4L engine. '98 Forester would have a Phase I 2.5L - that's the EJ25 - stear WAY clear of that engine. '99 and up Forester's have the Phase II. There has never been a factory 2.3 or 2.4. EJ15, EJ16, EJ18, EJ20, EJ22, EJ25...... GD
November 27, 200916 yr Author Umm... I must have missed something with that link cause the price of their weakest engine is 13K... i don't want to spend 1,300... I'm trying to get this done.. completely done car and all for less than 800.
November 27, 200916 yr Author '98 Forester would have a Phase I 2.5L - that's the EJ25 - stear WAY clear of that engine. '99 and up Forester's have the Phase II. There has never been a factory 2.3 or 2.4. EJ15, EJ16, EJ18, EJ20, EJ22, EJ25...... GD Ok cool... figured that they might have gotten that wrong.
November 27, 200916 yr I didn't mean for you to buy it. Just to let you know, indeed, there is a 2.3:)
November 27, 200916 yr Author But you're getting the new tires, radiator, alt... It shouldn't be hard or pricey to locate an engine. Doug I'm in Indiana..everything subaru is pricy and and hard to locate lol.
November 27, 200916 yr I'm trying to get this done.. completely done car and all for less than 800. That's a tall order. You aren't going to find anything that doesn't need work for $500 or less. I'll be at around $800 when I'm done with the '91 I just bought and I only paid $250 for the car. And that's a DEAL. GD
November 27, 200916 yr Author I didn't mean for you to buy it. Just to let you know, indeed, there is a 2.3:) oh ok cool lol
November 27, 200916 yr Author That's a tall order. You aren't going to find anything that doesn't need work for $500 or less. I'll be at around $800 when I'm done with the '91 I just bought and I only paid $250 for the car. And that's a DEAL. GD I just need a good short block.
November 27, 200916 yr I didn't mean for you to buy it. Just to let you know, indeed, there is a 2.3:) There's a 2.35L - that's an EJ22 with EJ25 crank and rods. Basically an EJ22 stroker. Not a factory engine though and typically not done unless you are planning to built an 800 HP monster turbo engine. GD
November 27, 200916 yr Author I know that to do the oil pump, water pump, timing belt w/ tensioners, HVLAs, are cam seals would cost me just over 300 on ebay for everything... how much could a rebuild kit or short block really cost?
November 27, 200916 yr I just need a good short block. You won't find that easily in the EJ25 phase I. That's what fails the most on them besides head gaskets. Rod failure and piston slap are very common with that engine. Coupled with the terrible head gaskets - the EJ25 phase I is to be avoided at all costs or swapped out with an EJ22. GD
November 27, 200916 yr Author You won't find that easily in the EJ25 phase I. That's what fails the most on them besides head gaskets. Rod failure and piston slap are very common with that engine. Coupled with the terrible head gaskets - the EJ25 phase I is to be avoided at all costs or swapped out with an EJ22. GD I need a good ea82 short block.
November 27, 200916 yr Which short block do you need? I'm lost in your post here - you are all over the map with EA82's and EJ25's...... GD
November 27, 200916 yr Author Which short block do you need? I'm lost in your post here - you are all over the map with EA82's and EJ25's...... GD EA82... I was considering a donor vehicle with the EJ engine in it but I"m not wild about that idea.
November 27, 200916 yr The only good EA82 short block is the one on the end of the anchor chain..... Used engines are a dime a dozen. You probably won't find just the short-block - you'll have to buy a whole engine to get one most likely. GD
November 27, 200916 yr Author The only good EA82 short block is the one on the end of the anchor chain..... Used engines are a dime a dozen. You probably won't find just the short-block - you'll have to buy a whole engine to get one most likely. GD LOL.... forgot your the EA hater
November 27, 200916 yr LOL.... forgot your the EA hater if you're looking for a cheap EA beater just buy one and do the headgaskets. if it's done right and not a turbo they can last a really long time. problem is their value isn't in the vehicle at all, zero value. they're value is in you can make 100,000 miles really cheap with them, that's about it. There's a few that can get 35-40 mpg but noone wanting good mileage wants an older car like this. I'm in Indiana..everything subaru is pricy and and hard to locate lol. Complete EA82's: 1-866-480-7278 $350 in Gary, IN 219-981-0122 in Merriville, IN 1-800-225-9025 $150 for just a short block in Columbus, IN Edited November 27, 200916 yr by grossgary
November 27, 200916 yr Guess I missed something but your original post says TOD? that doesn't require engine replacement at all. if you got a cheap EA82 just run the thing forever with TOD, turn your radio up. throw an oil pump and new seals at it and call it a day.
November 27, 200916 yr LOL.... forgot your the EA hater Not *the*, but definitely *one* of them. There are quite a few of us. Try eBay - there are quite a few recyclers that post engines and such. I shipped a short-block across the country for like $75 about a year ago. GD
November 27, 200916 yr "The only good EA82 short block is the one on the end of the anchor chain....." The Rodney Dangerfield of Subaru engines. I think he is like "The Anti-EA-82". A thorn in his side, for sure. Doug
November 28, 200916 yr Author Guess I missed something but your original post says TOD? that doesn't require engine replacement at all. if you got a cheap EA82 just run the thing forever with TOD, turn your radio up. throw an oil pump and new seals at it and call it a day. TOD AND rod knock... it's the latter half that justifies replacement.
November 28, 200916 yr Author Complete EA82's: 1-866-480-7278 $350 in Gary, IN 219-981-0122 in Merriville, IN 1-800-225-9025 $150 for just a short block in Columbus, IN $150 WOW!!! thre's hope yet
November 28, 200916 yr TOD AND rod knock... it's the latter half that justifies replacement.oh come on you're gutless! just kidding, i never saw that. well good you got heads and all then, you just need a block.
