glcoupeguy Posted January 15, 2010 Share Posted January 15, 2010 so i have everything pulled and the EJ20 is in the machine shop and im going with about 12-15 pounds of boost. i was wondering how other people have approached this. im not sure if im going to get a stock turbo or not. i was wondering where other people have placed their aftermarket turbos/intercoolers and how they routed the piping. im not really keen on putting an intercooler under the bumper because i think its kinda ugly. ive already fashioned a hoodscoop so placing it in the spare tire well would be preferable. pictures would be excellent! heres a youtube video from last summer when the scoop was almost finished Quote Link to comment Share on other sites More sharing options...
Turbone Posted January 15, 2010 Share Posted January 15, 2010 Mine still has the EA82T in it (for now), but it has a TD04 and WRX IC. Quote Link to comment Share on other sites More sharing options...
Subarutex Posted January 15, 2010 Share Posted January 15, 2010 Keep the turbo in the stock location (unless you have twins, if thats the case, you'll be best to convert it to a single turbo setup). Start by running a Top Mount (TMIC) like Turbone and I. This is plenty of cooling for stockish power. Really, you don't need to go front mount (FMIC) till you are in the neighborhood of 300hp at the wheels. Quote Link to comment Share on other sites More sharing options...
glcoupeguy Posted January 16, 2010 Author Share Posted January 16, 2010 (edited) hmmm... it might get close to 300 (250+) as far as the machinging goes... im pretty much getting the full meal deal... with large fries - 8:1 compression crower pistons, DOHC delta cams, polishing, balancing ect Edited January 16, 2010 by glcoupeguy Quote Link to comment Share on other sites More sharing options...
Subarutex Posted January 16, 2010 Share Posted January 16, 2010 hmmm... it might get close to 300 (250+) as far as the machinging goes... im pretty much getting the full meal deal... with large fries - 8:1 compression crower pistons, DOHC delta cams, polishing, balancing ect I hope you have a good engine management. Quote Link to comment Share on other sites More sharing options...
glcoupeguy Posted January 25, 2010 Author Share Posted January 25, 2010 looking for a stand alone Quote Link to comment Share on other sites More sharing options...
Subarutex Posted January 25, 2010 Share Posted January 25, 2010 As someone that has a standalone EJ20... don't. I'd really try to go after the USDM swap route. With some wiring changes, and open source tuning you can easily get a JDM motor to work with it. Easier to tune, more drivability! Quote Link to comment Share on other sites More sharing options...
suberdave Posted January 25, 2010 Share Posted January 25, 2010 if you are doing a JDM EJ20? look into ViPEC. that is what i have and i love it. super easy to tune, and very drivable. i have had it on my daily driver for almost 15K now and love it... if going USDM EJ20? stock ECU with accesport or open source should do what you need... i have done 3 full EJ20 swaps 2 EJ20G's and one EJ207, and a few other subaru swaps. if you have any questions shoot me a PM... -=Suberdave=- www.suberdave.com Quote Link to comment Share on other sites More sharing options...
glcoupeguy Posted January 25, 2010 Author Share Posted January 25, 2010 (edited) its a 1990 block. im not sure which one (n/a) so just grab an OBD1 ecu? Edited January 25, 2010 by glcoupeguy Quote Link to comment Share on other sites More sharing options...
suberdave Posted January 25, 2010 Share Posted January 25, 2010 I dont think a NA ECU will work without some sort of piggieback ECU. as soon as the NA ECU sees boost it will freak out... you need to check out; http://forums.nasioc.com/forums/forumdisplay.php?f=50 it is a Normally Aspirated with bolt-on Forced Induction Powertrain fourm on NASIOC... if i were you i would buy a factory turbo exhaust manifold and up pipe, along with a factory downpipe. this will put your turbo in a nice easy location, with lots of turbo options. Quote Link to comment Share on other sites More sharing options...
bluto5 Posted March 10, 2010 Share Posted March 10, 2010 (edited) I'll be running a stinger ems. It's about the equivelant of megasquit but handles older subarus timing sensors in it's stock config. Bigest downer is no avcs control, I'll have to upgrade ems if I go that route. Megasquirt can now handle 2001+(I think that's the right year) Subaru timing cofiguration now FYI. They still don't have any avcs control either though. I'm setting up an ej22t block and 2.5 dohc heads. Sam ps... As for turbo location, I'm building an up pipe to rotate a stock type turbo, just as easy to build 2 as one.. Maybe even replicate my topmount setup. My car is an 89 rx. Edited March 10, 2010 by bluto5 Quote Link to comment Share on other sites More sharing options...
