February 17, 201016 yr While the heads are off, what other things that are hard to reach, would it make sense to may be preventively replace now, in order to save trouble later? PCV? Temp sensor(s)? -Michael
February 17, 201016 yr So you want the entire list? you dont say how many miles. Valve cover gaskets Sparkplug gromits Plugs PCV valve Thermostat Timing belt Idlers Tensioners Main Seal Cam Seal Accessory drive belt Water pump Oil Change Ignition Wires
February 17, 201016 yr Without knowing prior maintenance then +1 to all that nipper said. And i'll add reseal the oil pump and tighten the rear backing plate screws with thread locker.
February 17, 201016 yr Author It has 135K miles. The headgasket was replaced less than 1 year, about 10K miles ago... together with all belts, not sure about seals. I am not doing it myself, it's at the shop now.
February 18, 201016 yr << It has 135K miles. The headgasket was replaced less than 1 year, about 10K miles ago... together with all belts, not sure about seals. I am not doing it myself, it's at the shop now. >> why are you doing a valve job now?
February 18, 201016 yr Author << It has 135K miles.The headgasket was replaced less than 1 year, about 10K miles ago... together with all belts, not sure about seals. I am not doing it myself, it's at the shop now. >> why are you doing a valve job now? That's in another thread: (http://www.ultimatesubaru.org/forum/showthread.php?t=108885) Question: 02' Legacy GT wagon- cold morning rough idle, misfire Edited February 18, 201016 yr by 740gle Link format
