February 22, 201016 yr My '88 DL with 200k refuses to start. Not even a slight catch. turns freely. I have checked the fuel delivery (spfi), checked the spark (New distributor etc.) and it looks good. I tried doing a compression check by turning the motor over, and I can't get an accurate reading. Maybe I'm not doing it right. Any other things that could be wrong? I am suspecting bad head gasket leaks. It has newer timing belts.
February 22, 201016 yr Have you checked the timing belts? The belts themselves might be new, but that doesn't help if a tensioner seizes. Rip off the two outer inspection covers and just take a peek. 5 minutes work or less to definitely make sure its not the belts.
February 23, 201016 yr New distributor etc. Have you rechecked the spark timing after the distributor was off?
February 24, 201016 yr Author Have not checked the timing, but did compression test today, and the left-side cylinders both test 0, so I'm thinking a blown head gasket at least, if not a cracked head. Is it worth doing the heads, or should I get a new motor? I imagine it's pretty tired at 200k anyway.
February 24, 201016 yr Have not checked the timing, but did compression test today, and the left-side cylinders both test 0, so I'm thinking a blown head gasket at least, if not a cracked head. Is it worth doing the heads, or should I get a new motor? I imagine it's pretty tired at 200k anyway. I'm pretty sure thats a belt gone right there bud.
February 24, 201016 yr i hope you come back to let us know what you find out! i second a broken timing belt, driver side belt. take off the cap and see if the rotor turns when you crank the motor, easiest way to tell.
February 25, 201016 yr It does sound like it could be a timing belt, with a valve stuck open on each head. But, if after all this there is still spark, then that means the distributor is turning, so the belt isn't broken in that case. If the cam is turning and you still have 0 compression, then it's the head gasket or something worse. Edited February 25, 201016 yr by msteel
February 25, 201016 yr You stated the left side of the engine has no compression and I assume you mean the driver side when you say that. I thought the left side cam drove the disty shaft but maybe I am mistaken. If it is the left side then the rotor isn't turning in the disty most likely. I would have to say for sure the timing belt has broke on that side. You couldn't have that low of compression without serious engine damage otherwise and it would be very 'obvious to the most causual observer'.
February 25, 201016 yr Cougar, you are right. The driver side timing belt does drive the distributor. It's not that often these blow HG's...non turbo's atleast. Before you start worrying about a motor, zero compression on one side is a pretty good start. Pull the timing belt covers off and see if one broke. It's not difficult, just a few 10mm's. And it's super common for this to happen, many of us run without timing covers for this reason Or, as stated, you can pull the disty cap off and see if the rotor is turning. If it isn't, then I'd say the driver side belt is off at the least.
February 25, 201016 yr Thanks for the confirmation about the cam drive for the disty 94Loyale. If the belt is broken for that side then just removing the disty cap and watching for rotation while cranking the engine will verify the belt status.
March 5, 201016 yr Author So, I pulled the distributor cap and it rotates just fine. It's pretty new as well. I will pull the timing belt cover and have a look-see but head gasket or worse is sounding very likely. Also, last time it ran it blew white smoke pretty bad, and the coolant level is low after filling it up before testing began.
March 9, 201016 yr sounds like a blown headgasket to me! i just did my headgaskets but now its not starting.. timingbelts are good and the timings correct but i think the disty is off? maybe no spark.. not sure yet..
March 9, 201016 yr well i must say gray or white smoke is a good indication of blown head gasket. so it has been everytime i have had that happen. in everything i have had smoke like that. all were not subaru. as for timing. if is not the headgasket and no cylinder pressure on one side i had that problem when i had timed the belts useing the zero degree mark on the flywheel. but which a little usmb readin on the manual. i went back and did it right. i had that not starting problem, then when i did it right by the usmb manual it starts and runs. well it now starts but wont stay running. off by a tooth i think. have not had time to get back to it.
April 8, 201015 yr Author Finally pulled the timing cover off the driver's side head, and lo and behold, the belt was not only off, but chewed up pretty good. New belt, tensioner springs, and the old gal started right up! Thanks for the help.
