98 OBW Power Steering Pump leaking!
  • 1 month later...
Correction to previous post:
For the '97 OBW, PS reservoir O-ring is closer to 11x15x2mm, probably nitrile.
Don't know the hardness (70, 90)?
Get the right one from the dealer when replacing. Even if you get close with a metric kit o-ring it can still leak. Another key might be centering the reservior outlet in the pump inlet so the o-ring isn't crushed on one side.
