steering knuckle
Will a steering knuckle from a 1990 Legacy fit a 1995 Legacy? Both AWD both automatics.
Thanks
I would say yes. i have used a 1993 transmission in a 95 legacy, i was able to fit an xt6 knuckle in the 95 legacy.
there may be differences with the rotor or caliper bracket, but just swap over the parts you need.
there will be differences in the strut top bolt spacing. the knuckle end of the strut is the same. use the 1st gen struts, or at least the 1st gen strut tops on a 2nd gen strut(if you are using the strut too)
yes, if they are both ABS. or if neither is ABS.
maybe, if one is and one is not, it depends which has / needs ABS.
95 will have ABS 90 will not. therefore, it will fit, but you wont be able to use your ABS sensor, so it wont work correctly.
My 95 doesn't have ABS, but thanks for all the info. I'm going to the bone yard Monday to get some parts.
