dgarlepp Posted March 17, 2010 Share Posted March 17, 2010 Will a steering knuckle from a 1990 Legacy fit a 1995 Legacy? Both AWD both automatics. Thanks Quote Link to comment Share on other sites More sharing options...
MilesFox Posted March 17, 2010 Share Posted March 17, 2010 I would say yes. i have used a 1993 transmission in a 95 legacy, i was able to fit an xt6 knuckle in the 95 legacy. there may be differences with the rotor or caliper bracket, but just swap over the parts you need. there will be differences in the strut top bolt spacing. the knuckle end of the strut is the same. use the 1st gen struts, or at least the 1st gen strut tops on a 2nd gen strut(if you are using the strut too) Quote Link to comment Share on other sites More sharing options...
johnceggleston Posted March 17, 2010 Share Posted March 17, 2010 yes, if they are both ABS. or if neither is ABS. maybe, if one is and one is not, it depends which has / needs ABS. Quote Link to comment Share on other sites More sharing options...
bheinen74 Posted March 17, 2010 Share Posted March 17, 2010 95 will have ABS 90 will not. therefore, it will fit, but you wont be able to use your ABS sensor, so it wont work correctly. Quote Link to comment Share on other sites More sharing options...
dgarlepp Posted March 18, 2010 Author Share Posted March 18, 2010 My 95 doesn't have ABS, but thanks for all the info. I'm going to the bone yard Monday to get some parts. Quote Link to comment Share on other sites More sharing options...
pearlm30 Posted March 18, 2010 Share Posted March 18, 2010 There are a few 95 and 96 legacys @ u pull and pay in orlando if you are willing to drive a little. http://www.upullandpay.com/Locations/orlando/default.aspx Go to search inventory Good luck My 95 doesn't have ABS, but thanks for all the info. I'm going to the bone yard Monday to get some parts. Quote Link to comment Share on other sites More sharing options...
dgarlepp Posted March 18, 2010 Author Share Posted March 18, 2010 cool, thanks Quote Link to comment Share on other sites More sharing options...
