April 12, 201015 yr Hey Guys, my other project, (Dodge Colt) is getting some new parts. Does this flywheel look like it needs turning? It's very smooth, no ridges. Those lines are not grooves. 56 K on it. Some rust only from sitting. Your thoughts? Thanks! Todd
April 15, 201015 yr I agree - it could be "wavy" and the smooth surface will not seat in a new disc very well. In the same way that roughing up a rotor when you replace brake pads it's always a good idea to mill a flywheel so you know for a fact it's completely flat and will seat the disc in properly. The $35 cost is definitely worth it considering what's at stake (pulling the engine or tranny back out ). GD
