lastchance Posted June 24, 2012 Author Share Posted June 24, 2012 quick answer: http://www.amazon.com/Bosch-SR176N-New-Starter/dp/B000BZN69Q/ref=au_pf_ss_1?ie=UTF8&Model=GL|59&n=15684181&s=automotive&Make=Subaru|13&Year=1984|1984&carId=002 bosch rocks my world, those reman starters from advance/auto zone/o'reilly are a joke. i blew through four starters thinking it was everything from the ignition switch, to the switch harness, to the relay, to the battery, to the cables, and so on. long answer: i bought a multimeter, printed the wiring diagram out for my car and started troubleshooting. the mature, realistic approach to old subarus far trumps quick fixes and stupid money wasting crap. after everything checked out (relays, fuses, etc - continuity across circuits, voltage where it should be and so on) I bought the NEW bosch starter above and it's never started better. the old one was returned to advance where it blew the breaker on the bench testing machine twice (something was obviously grounded internally) and the guys were thoroughly amazed the starter was "that bad". note to self - use multimeter first rather than just throwing money at it, take your time to really think about what's happening and why, then move on and make repairs. Quote Link to comment Share on other sites More sharing options...
Cougar Posted June 25, 2012 Share Posted June 25, 2012 Glad you got it working. The bad short inside the starter was most likely due to the head of the stud bolt for the main cable connection. The bolt can be over tightened which causes the square head inside the starter to move and then contact chassis ground. When power is applied to it....Blam. Quote Link to comment Share on other sites More sharing options...
lastchance Posted June 25, 2012 Author Share Posted June 25, 2012 Glad you got it working. The bad short inside the starter was most likely due to the head of the stud bolt for the main cable connection. The bolt can be over tightened which causes the square head inside the starter to move and then contact chassis ground. When power is applied to it....Blam. i see. i'm always worried about breaking or mucking up stuff on the car, looks like the incredible hulk approach isn't always good. :-p Quote Link to comment Share on other sites More sharing options...
Cougar Posted June 25, 2012 Share Posted June 25, 2012 Yep, you got it. All you need is reasonably tight. If the stud does turn and cause the problem it is pretty easy to turn it back slightly and clear the short. Over tightening the battery post clamps is a real common problem. It stretches the clamp out and damages it. Tightening the clamp just enough so it dosen't turn on the post is good enough and making sure the connections are clean are a good thing. It is amazing how many folks have electrical trouble just due to dirty battery connections that get over looked. Quote Link to comment Share on other sites More sharing options...
lastchance Posted November 11, 2012 Author Share Posted November 11, 2012 starter is dead again. :banghead: what are the chances the flywheel teeth are gnarled up, causing me to burn through starters? Quote Link to comment Share on other sites More sharing options...
naru Posted November 11, 2012 Share Posted November 11, 2012 Easy enough to inspect the teeth with the starter removed. I had trouble w/the wire between the battery and the fusible link box on my 84 turbo. What does the multimeter say this time? Quote Link to comment Share on other sites More sharing options...
lastchance Posted November 23, 2012 Author Share Posted November 23, 2012 Well, battery (brand new Optima RedTop) was showing 10.8v at rest, hooked it up to my trusty Shumucher charger and got it back to full charge in no time. Also threw in new 2 gauge battery cables and cleaned the connections super well. Battery goes back in, starts right up no problems. Never underestimate low battery charge levels. Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted November 23, 2012 Share Posted November 23, 2012 Hm maybe they hadn't charged the battery in a long time. I have a yellow top that is 10.8v at rest too. Unfortunately yes it will still start the car but it has shorted cell in it so its not ideal. Optima suffered some quality issues a few years back, seen many postings of shorted cells. I switched to Odyssey after that. Quote Link to comment Share on other sites More sharing options...
lastchance Posted November 23, 2012 Author Share Posted November 23, 2012 I bought the battery in June, installed it, drove it maybe 5-6 times (short distances, 17 miles total) that month and then let the car sit until last week. I'm sure not letting the alternator do work and sitting in a cold shop for 5 months killed it. Quote Link to comment Share on other sites More sharing options...
pupp018@yahoo.com Posted September 2, 2019 Share Posted September 2, 2019 Im having similar issues with my 1998 Subaru Impreza L wagon 2.2 New Starter, New Neg cable, New Ignition Switch Cleaned all Ground contacts Battery Holds a Charge When It just Clicks when I turn the key, The clock on the dash shuts off, and the Radio loses power as well, but the first click Power is fine "Turn Click, Turn Click, Turn Click," Somedays It just clicks, some days it fires right up, Its a hit a miss, Trying to PinPoint the issue Any feedback will Help, Thanks in advance! Quote Link to comment Share on other sites More sharing options...
silverhelme Posted September 2, 2019 Share Posted September 2, 2019 Do a search for starter relay mod. I did it to my Brat and never had another problem. It's been ten years. 1 Quote Link to comment Share on other sites More sharing options...
pupp018@yahoo.com Posted September 3, 2019 Share Posted September 3, 2019 Where would I add the Starter Relay Mod? Sorry lol Quote Link to comment Share on other sites More sharing options...
silverhelme Posted September 3, 2019 Share Posted September 3, 2019 (edited) It is added between existing starter solenoid wire and starter. See this post and scroll to post ten by jono for the fix. Edited September 3, 2019 by silverhelme incomplete 1 Quote Link to comment Share on other sites More sharing options...
pupp018@yahoo.com Posted September 18, 2019 Share Posted September 18, 2019 Ok, Its been 2 weeks now, Its fired up every time :D I will probably return for another update in the near future on how the cars doing, Thank you so much silverhelme For giving me the link to find my problem. Much appreciated! Quote Link to comment Share on other sites More sharing options...
loyalematt Posted September 21, 2019 Share Posted September 21, 2019 I had a similiar problem where the connection in the ignition switch was faulty. Ended up running a push button start wired from the positive batt terminal to the button, button to the wire that clips onto the starter at the back. Works every time. Quote Link to comment Share on other sites More sharing options...
