May 10, 201015 yr so here we go, i, like so many others desire to lift my loyale cheaply and with scrapyard parts, ive heard rumors that forrester struts bolt right in. while this appears to be true the spindles are different. a 5-lug conv. may be in order. any help would be sweet
May 10, 201015 yr the rumors were about imprezas. 5-lug swap is possible. but if you want a lift, just buy a lift. much cheaper and simpler! http://www.sjrlift.com
May 11, 201015 yr so here we go, i, like so many others desire to lift my loyale cheaply and with scrapyard parts, ive heard rumors that forrester struts bolt right in. while this appears to be true the spindles are different. a 5-lug conv. may be in order. any help would be sweet When I read the title I was like "Retrofitting Loyale suspension to a Legacy? What the hell??"
May 11, 201015 yr Author did i say legacy? i meant forrester to loyale. as lifts are cheap i know i should do it right but raising a subaru and a daughter is tough on 10 bucks an hour. so no go on the rumors then? my last trip to the junkyard revealed that the bolts will fit in to the towers on the loyale. custom halfshafts to go to 5 lug?:-\
May 11, 201015 yr loyale and legacy 2 different animals, if you do add longer rear shocks make sure you drop the diff also
May 11, 201015 yr i suggest instead of jumping around the board asking a bunch of questions that have been answered several times, to search.and read.i bet it would help alot.
May 11, 201015 yr did i say legacy? i meant forrester to loyale. as lifts are cheap i know i should do it right but raising a subaru and a daughter is tough on 10 bucks an hour. so no go on the rumors then? my last trip to the junkyard revealed that the bolts will fit in to the towers on the loyale. custom halfshafts to go to 5 lug?:-\ 5-lug swaps are possible. But, as I said, lifts are possible and cheap already. if you're going for an offroad look, lift it as-is, and re-drill the hubs to 6-lug for wheel selection.
May 12, 201015 yr to clarify, what year/model of subaru are you trying to lift? if it's a loyale/GL/DL- than you should skip trying to make the legacy/forester/outback struts work (unless you DO the 5-lug swap, but that's even harder than just lifting AND usually in the long run, more expensive too) 4wd GL wagons seemed to have the tallest struts out of the bunch? (or maybe it was a certain year/ had adjustable one's for the rear too...) another way to get some lift- bigger tires. If you have an EA car, just trim the fenders a little, and you can fit 27's in there pretty easily without a lift or funky adjusted struts...
