XT6 sway bar upgrade
Ive read some of the previous posts and im wondering if the xt6 front and rear sway bar will bolt up to an 89 rx? Will this tighten up the handling in comparison to the stock sway bars?
i have XT6 sway bars on my ride, just got a WRX rear bar to experiment with.
ill report results when the car runs again.
Use them to tune the handling of the car like you want by
swapping out bars to suite your driving style. Might I suggest swapping and driving very conservatively for a
while to get used to the new characteristics of the car.
I have quite a collection of front and rear bars for my RX. and have gotten fairly proficient at swapping them for different circumstances.( I am a self-professed oversteer hound).
You can also set toe to effect turn in and stability for
gravel or pavement. Yes, it will affect tire wear, it's a trade off.
Regards,
Jay
Do let us know denis! that should be very interesting.
Jay, Is the handling really that much better that you have to be more conservative after the swap? Also what other sway bars do you use for your rx?
Mike
