nitsuj80 Posted July 6, 2010 Share Posted July 6, 2010 I was wondering if I would need to use a high temp paint for the valve covers/oil pan on a EA81 or would just any metal paint work? Thanks Link to comment Share on other sites More sharing options...
GeneralDisorder Posted July 6, 2010 Share Posted July 6, 2010 Any enamel should work fine. The valve covers don't get that hot as they are insulated by the cork gaskets. High temp paint would be adviseable on the engine block and heads, etc. GD Link to comment Share on other sites More sharing options...
2manetoys Posted July 7, 2010 Share Posted July 7, 2010 Any enamel should work fine. The valve covers don't get that hot as they are insulated by the cork gaskets. High temp paint would be adviseable on the engine block and heads, etc. GD Speaking of the valve covers and gaskets, any special treatment they need ( RTV ) before installing? And if I'm going to reseal the engine, I assume that I should wait until I have all the gaskets to do the Valve cover gaskets. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted July 7, 2010 Share Posted July 7, 2010 I coat the cork in a thin layer of RTV and let it dry. Keeps the cork from absorbing oil and dramatically extends it's life and sealing ability. All cork is NOT the same. Only get your pan and valve cover gaskets from the dealer. Aftermarket is junk - especially on the pan gasket. GD Link to comment Share on other sites More sharing options...
