July 30, 201015 yr Any tips, pictures, or links to previous how-to's? I have 1 valve (lifter) that is clicking almost continually and ready to see if it's an easy fix. Thank you for anything you have to offer.
July 30, 201015 yr valve cover gaskets are easy, just have a 10 mm ratcheting wrench available, takes all the frustration out of that job.
July 30, 201015 yr valve cover gaskets are easy, just have a 10 mm ratcheting wrench available, takes all the frustration out of that job. Awww, but that takes all the fun out of it... As for cleaning your oil passages, I highly recommend using a quart of ATF in place of a quart of oil on your next oil change or running seafoam in the oil for 5-10 minutes before you do your next oil change. There are many write-ups on how to use seafoam, just do a quick search using the keyword "seafoam" and you'll get plenty. Twitch PS: Make sure you clean your valve covers immaculately otherwise you could end up with a leak. Edited July 30, 201015 yr by Twitch de la Brat
July 30, 201015 yr Might want to try a bottle of MMO (Marvel Mystery Oil) in the crankcase. Drive the car for a few days and see if the clicking goes away, then change your oil & filter. Good luck.
July 30, 201015 yr Author Thank you guys! Would you recommend the ATF or Seafoam first? Also, have you ever taken the rockers off to clean the oil passage? Any pics? It's a tick that is off and on randomly at any RPM. Seems like it's slow enough to be one rocker...
July 30, 201015 yr Thank you guys! Would you recommend the ATF or Seafoam first? Also, have you ever taken the rockers off to clean the oil passage? Any pics? It's a tick that is off and on randomly at any RPM. Seems like it's slow enough to be one rocker... In your case I'd go for the ATF first, as it seems your problem is just from lots of wear and may need some minor cleaning. 250k is up there for just about any EJ. Plus the additives in the ATF would probably be good for your seals where as seafoam tends to be hard on those. Good luck and hope your tick goes away! Twitch
July 30, 201015 yr Author I'll probably change gaskets, add ATF. and then change oil tomorrow. I'll let you know what happens.
July 31, 201015 yr If you're taking it apart, I would definitely snake the oil passages you can access. There was a note on endwrench about ticking on some engine that was attributed to a plugged passage there. I snaked mine with a piece of 14 ga bare copper wire (not sure if that was a good idea to use that or not).
