valve repair
just trying to get an estimate on what i would have to pay my mechanic to replace a bent valve. it's a 1986 subaru gl wagon. 1.8l
whats your location, it might be easier and cheaper to get a new head at the junkyard. however unless your in the Pacific North West that may be easier said than done. I don't know prices on new valves in heads, but there will be a certain amount of machining to be done to make the new valve fit, it would be bennificial at this time to get both heads off and put in all new valves and guides, and possibly seats if there hammered
who is taking the head off/ you or the mechanic? if you have the head off yourself, you may want to invest in a valve spring tool, it will pay for itself if you do valve seals on your own work, the tool is cheaper than the mechanic
but if you have the head off, the mechanic wouldnt cost as much, buit he will still charge you an hour at rate
Why do you think you have a bent valve? The valves in the EA82 heads are HUGE and incredibly strong. Plus the engine is interferential. I mean, this would be really unusual and very rare.
So, what makes you think you have a bent valve?
Emily
http://www.ccrengines.com
without looking at the car yet, that's what the mechanic told me over the phone, that it was probably a valve problem. it all started when i broke the timing belt. once the belts were replaced---------engine misfires and no compression. i thought since it was noninterferance engine, once belts were replaced everything would be cool
I think Emily may have made a typo. The engine is noninterferential. A broken timing belt will not cause a bent/broken valve. I would be more inclined to believe that the timing belts were installed incorrectly. That would cause it to run like crap and have low compression.
sounds to me that if the car runs bad AFTER BEL SERVICE, they were installed wrong
you can check the belt timing by removing the outer belt covers, and the bellhousing window rubber plug
read this if tou would like to check the belt timing yourself, or show this to your mechanic
http://www.warpthree.com/milesfox/subaru/service/timingbelt.htm
that's what i'm thinkiing. although i thought all you had to do was line up the markings
there are some 720 deg crank rotation for the procedure
line up the first cam, rotate 360 deg, line up the other cam, rotate 360. then rotate again to bring the first cam back to the peginning step, them rotate till you get 0degBTDC to do the distributor
the belt alignment marks will line up when ALL the pistons are in the middle of their stroke, NOT the ignition timing
its common for a mechanic to line up both belts up, to odeg tdc, when the cams should be pointing opposite, with the 3 marks in line
also, if it was a valve problem wouldnt it be smoking or be making some type of internal noise ?
Yep, NON interferential is what I meant. Yep, yep, yep.
:D
(That's what happens when I try to type before coffee!)
Look to the timing belts. Problem is extremely likely to be there.
Emily
what's the normal charge for a mechanic to replace timing belts on the 86 gl anyway?
i myself would charge 100 bucks, and do the axle at the same time! anyway, that is what im charging the local service garage to commission me to service his customers soob, 5 hrs, 20 bucks/hr
