October 9, 201015 yr I was torqueing the heads on my EA81 when I pulled the threads out of the last stud. My question is do I need to replace the head gasket since I had about 42 lbs. of torque on it or should it be fine to use once I get the stud fixed. Thanks
October 9, 201015 yr if you're taking the head gasket off and talking about reusing it, i'd get another one. not worth the few dollar risk for such a big job to me. Edited October 9, 201015 yr by grossgary
October 9, 201015 yr I'll second that. If it's already been compressed $15.00 or so should get you a new one.
October 10, 201015 yr I had the same thing happen on an EA82. Had already repaired one stripped thread, then on the last tightening sequence another one pulled out Heli-coiled it (again), used the same head gasket, and the car is running fine. YMMV
October 10, 201015 yr I have no prior experience with this but, I'd re-use it. Mostly,because if it didn't work out,I wouldn't mind too much doing it over.
October 11, 201015 yr Unless you have far more time than money, I would replace it. On a slightly different topic, the thread repair kits on the EA81/82 are uncommon and expensive ($70-ish for Helicoil when I was looking recently). 11Mx1.25 thread. Good luck.
