Weber manual choke through the firewall
I'm going to order a Weber with a manual choke from carbsunlimited.com. It's going in my '87 GL. How to you run the choke lever (or linkage, I don't know the proper term) through the firewall?
I was also thinking about ordering the water choke instead. They aren't a big deal to hook up, are they? It seems like it would just be one in hose and one out hose.
Thanks.
From what I've read the water choke is more accurate than the electric choke. I wouldn't mind having the electric but the water choke is only 10$ more.
It might be but then you have an additional coolant line to run, break, and deal with. The electric is already there with a factory wire you can use and most of the ones I have done or seen utilized the spade from the factory harness.
