October 20, 201015 yr I'm going to order a Weber with a manual choke from carbsunlimited.com. It's going in my '87 GL. How to you run the choke lever (or linkage, I don't know the proper term) through the firewall? I was also thinking about ordering the water choke instead. They aren't a big deal to hook up, are they? It seems like it would just be one in hose and one out hose. Thanks.
October 20, 201015 yr Yes, Water Choke is not a Big Deal, but Could I Ask Why Don't you Order the Electric Choke Version?
October 20, 201015 yr Author From what I've read the water choke is more accurate than the electric choke. I wouldn't mind having the electric but the water choke is only 10$ more.
October 21, 201015 yr It might be but then you have an additional coolant line to run, break, and deal with. The electric is already there with a factory wire you can use and most of the ones I have done or seen utilized the spade from the factory harness.
