84GLPROJECT Posted October 22, 2010 Share Posted October 22, 2010 So I have a '79 Brat and its pretty solid, except the engine. I need to replace all the gaskets and possibly the carburetor. If you have any sources on where to get this stuff or have any laying around that would be awesome. Thanks for reading Quote Link to comment Share on other sites More sharing options...
moosens Posted October 22, 2010 Share Posted October 22, 2010 I'll check back later or tomorrow but no time right now. I should be able to help you out if somebody else doesn't step up. I do have a carb I was going to rebuild last winter/this winter and also can offer a carb rebuild kit. And I have a full engine gasket/seal set too. You can find those on eBay fairly often and for what I'm going to ask anyways. Carbs also show up ,one was just on recently. Gotta fly ,check back soon. Paul Quote Link to comment Share on other sites More sharing options...
84GLPROJECT Posted October 27, 2010 Author Share Posted October 27, 2010 Thanks, I'm not sure what exactly I need yet but I know I need an exhaust manifold for sure, if you know where I could get one that would be awesome Thanks again Quote Link to comment Share on other sites More sharing options...
moosens Posted October 27, 2010 Share Posted October 27, 2010 You mean the Y-pipe up front , right? I've got one with the pipe-to-head flanges turned 90 deg. if you're interested. Would be a bear to ship but could be done for probably under $40. I'd like to get $150 for the pipe since its getting super hard to find and still has plenty of life left in it. With the flanges turned you get to use the holes that were never used previously so that's a plus. But the inner studs are dang close to the engine mounts and need to be carefully inserted ,possibly with the engine slightly lifted. Or maybe need to keep the mounts loose untill the Y-pipe is on. The stud itself will clear , but the nut hits the mount with the engine seated inplace. I was just about to go thru all that when I decided to stick with my original pipe and just Helicoil the old holes. This pipe also has the "stove pipe" on the passenger side which your carb warmer tubing goes onto. "ctsuba" might have a 1600 Y-pipe to offer as well. He's also in CT Quote Link to comment Share on other sites More sharing options...
Subieguy Posted October 28, 2010 Share Posted October 28, 2010 You should be able to ship the Y-pipe easily through UPS. I had one shipped to me for only $17.00. All you need to do is wrap up the ends with some cardboard and tape. They will ship it just like that You mean the Y-pipe up front , right? I've got one with the pipe-to-head flanges turned 90 deg. if you're interested. Would be a bear to ship but could be done for probably under $40. I'd like to get $150 for the pipe since its getting super hard to find and still has plenty of life left in it. With the flanges turned you get to use the holes that were never used previously so that's a plus. But the inner studs are dang close to the engine mounts and need to be carefully inserted ,possibly with the engine slightly lifted. Or maybe need to keep the mounts loose untill the Y-pipe is on. The stud itself will clear , but the nut hits the mount with the engine seated inplace. I was just about to go thru all that when I decided to stick with my original pipe and just Helicoil the old holes. This pipe also has the "stove pipe" on the passenger side which your carb warmer tubing goes onto. "ctsuba" might have a 1600 Y-pipe to offer as well. He's also in CT Quote Link to comment Share on other sites More sharing options...
SUBARU3 Posted October 28, 2010 Share Posted October 28, 2010 I have lots of mechanical parts, gaskets, seals, carburetors. Email me your needs and I see what I have. Todd subaru3@aol.com Quote Link to comment Share on other sites More sharing options...
moosens Posted October 28, 2010 Share Posted October 28, 2010 You should be able to ship the Y-pipe easily through UPS. I had one shipped to me for only $17.00. All you need to do is wrap up the ends with some cardboard and tape. They will ship it just like that Nothing new to me .... but the $17 sure is !!! Across the country for $17 ? Quote Link to comment Share on other sites More sharing options...
Subieguy Posted November 1, 2010 Share Posted November 1, 2010 I got it shipped from washington state to California for that about 6 months ago. Nothing new to me .... but the $17 sure is !!! Across the country for $17 ? Quote Link to comment Share on other sites More sharing options...
84GLPROJECT Posted November 4, 2010 Author Share Posted November 4, 2010 Thanks for all the help guys, I'll be purchasing one soon I just need to come up with the money and the parts I need for certain Quote Link to comment Share on other sites More sharing options...
