November 11, 201015 yr Looking at a 80 4x4 Toyota pickup it has a 20r , anything I should know about this truck? what years are what , are the old ones the same as the new ones? as far as axle and drivetrain strength ? and interchangability ? EDIT**** bought a 82 it has a 5 speed with a 22R carbed Edited November 12, 201015 yr by Scott in Bellingham changed car
November 11, 201015 yr well its gonna likely have the typical toyota bed rust. the 20r motor is pretty strong and reliable. axels are good on those. what are you looking to do with it? muddin or daily driver?
November 11, 201015 yr wow, those things rusted in half here at the frame after the box.. none of the last 40 i looked at had a solid frame, even tho they said it was ok, i saw daylight thru each frame rail and hit it with my flashligt bottom and chunks fell out. goot luck
November 11, 201015 yr well a good wheeling yota is hard to beat for fun and reliability. How far are you looking to go with it. Basic mudder yota setup ive seen is huge tires and 5:29 gears. of course add some lockers. are you keeping the stock engine?
November 11, 201015 yr Author well a good wheeling yota is hard to beat for fun and reliability. How far are you looking to go with it. Basic mudder yota setup ive seen is huge tires and 5:29 gears. of course add some lockers. are you keeping the stock engine? shorten wheelbase , plop a Justy body on, run 33s , lockers, flex Edited November 11, 201015 yr by Scott in Bellingham details
November 11, 201015 yr Frames are usually fine around here. Body doesn't seem to be a priority. Engine run well without knocks or smoking. Has cross-over steering been done yet? J arms are the weak link of the steering. Looks like the right base for your progect though. How much?
November 11, 201015 yr Author Frames are usually fine around here. Body doesn't seem to be a priority. Engine run well without knocks or smoking. Has cross-over steering been done yet? J arms are the weak link of the steering. Looks like the right base for your progect though. How much? maybe a car trade , will see it today, its lifted on 33s
November 11, 201015 yr shorten wheelbase , plop a Justy body on, run 33s , lockers, flex nice. if you want more power toyota has a nice 3.4 turbo. if i ever get into engine conversions id do either that or a 4.3 vortec. 350 is good to a certain degree but it would make awful balance if its for flexing.
November 11, 201015 yr nice. if you want more power toyota has a nice 3.4 turbo. if i ever get into engine conversions id do either that or a 4.3 vortec. 350 is good to a certain degree but it would make awful balance if its for flexing. Neither engine will be a good choice for his build. 3.4 turbo has a late power curve. 350 in a toy is just asking for trouble. Yes, I know, they are all over the place. And 99% of them have over-heat issues and are unreliable. The only conversion I personally will do to mine is the 4.3. Good torque stock. But having access to torque cams makes it a no-brainer. FI and zero problems make it the right choice. Stick with the 20R and you'll be golden.
November 12, 201015 yr Author OK looked at the 80, didnt get, went and bought a 82' it has a 22r and a 5 speed this ones all stock, with 30s , Paid $700 is has been sitting and has oil in the rad water and needs a alt , does run and drive everythings there and works, will be parting out the body and bed, cabs in great shape beds got rust
November 12, 201015 yr Ok, will be parting out the body and bed, cabs in great shape beds got rust Nice score Scott. I need a part off that bed. I need one of the screws that holds the dealy that keeps the tail gate from falling down all the way when it's open.
November 12, 201015 yr Nice score Scott. I need a part off that bed. I need one of the screws that holds the dealy that keeps the tail gate from falling down all the way when it's open. Tailgate or bed side? I still have the blue tailgate.
November 12, 201015 yr Bed side, the tail gate doesn't affix with a screw, just a square knob that fits if you turn the dealybob sideways enough.
