torque question
coming live from my garager puter
i am in the middle of doing cam seals and oil pump seals
and can't find my book
what do i torque the cam keepers to and the oil pump bolts
I havent ever Torx'd anything on my car. I just do it by feel and the size of the bolt/nut that I am tightening.
tighten it till it almost snaps
i dont tighten it quite that much. Usually the really important things to be tight, aka crank pully, need to be tight as a mo-fo. Other things...just past snug...except for the turob bolts and nuts, which are just snug. Otherwise...they seize and break!
i have a tendancy to underestimate how much power i put on a ratchet and break stuff... even with short ratchets
but anyways its done just got a few things to do in the morning
thanx for the tips
14.8 ft/lbs is the high end of spec, which I would recommend going to for this part to avoid future leaks.
Do I count as a soob addict if I "just happen to have" an FSM sitting within reach of my computer chair?
