November 29, 201015 yr 95 legacy.On cold starts the power steering pump whines and dosen't provide much turning assistance. It stops after minute or so, then all is well. fluid level is good, no belt squeal,and I can't find any leaks. Think the pump has heard the 2 minute warning or is there a magic way to flush the system? Maybe a rack problem?
November 29, 201015 yr Pull off the cap, and check the fluid level. It might be low. If not low, then pump is prolly going bad. Replace with one from a wrecking yard. Cost is about $35.00
November 30, 201015 yr ALl you need to "flush" the system is a turkey baster. Just drain the fluid in the pump and refill it. If the belt is old replace it, that sounds like the issue. Belts get loose when cold and tighten up when hot.
