The Dude Abides Posted December 26, 2010 Share Posted December 26, 2010 Again still having lack of heat problems. Question, if the blend doors arent closeing could that result in a mild heat flow. Also there doesnt seem to be air flowing out of some of the vents on the dashboard. Only one in the middle seems to flow and the driver side spews alittle. Just curious if anyone has run into this before. Quote Link to comment Share on other sites More sharing options...
nipper Posted December 26, 2010 Share Posted December 26, 2010 Manually move the doors and see what happens. I dont know which sooby you have I could make other suggestion Quote Link to comment Share on other sites More sharing options...
mcbrat Posted December 27, 2010 Share Posted December 27, 2010 Again still having lack of heat problems. Question, if the blend doors arent closeing could that result in a mild heat flow. Also there doesnt seem to be air flowing out of some of the vents on the dashboard. Only one in the middle seems to flow and the driver side spews alittle. Just curious if anyone has run into this before. check the linkages under the dash. I had an 85 that had no heat, and after Shawn got it, he found there was a plastic connector in the linkage that was broken.... Quote Link to comment Share on other sites More sharing options...
