March 1, 201115 yr You guys were sooo right!! I waisted time and money to rebuild my hitatchi carb. Now I am ready to oreder the weber kit. My 87 brat has EA81 so I think the right kit is the K 730. I thought there was an old post with instructions for the swap. Any help really appreciated.
March 1, 201115 yr When I ordered my weber kit from redline. I recieved a really crappy adapter. It did not line up well, the holes where fine but the inside was crappy and didnt line up
March 1, 201115 yr http://www.jegs.com/i/Trans+Dapt/969/2107/10002/-1 Or search Trans Dapt 969-2107 I used one of these on an ea82. It is a nicer quality adapter than the one that comes in the redline kit. It is somewhat tall and with the tall K&N filter it would rub the hood on the car, with a low profile filter this would be solved (after I lifted the car this was a non-issue). I do not know if the Hitachi pattern is the same between the ea82 Hitachi and the one on your brat, maybe someone can chime in and confirm/deny this. Also, there is no throttle linkage included here, I modified a Loyale bracket to do the job. Finally, this adapter is made for a Datsun, not a Subaru. I did have to massage the bolt holes ever so slightly to get it to fit properly, but it was easily accomplished and successfully installed with no problems. I also believe the design of this adapter better blocks off the little water passage that is below the hitachi (again, on the ea82's, I'm not super familiar with that ea81 setup). Hope this helps someone!
March 2, 201115 yr Author I just ordered the K 730 weber kit from carbsunlimited, should be here Sat. I am very excited to drive the Brat again. Thanks for the info.
March 3, 201115 yr Sorry i didnt see this sooner but... If your carb comes with the 2.5" tall air filter you'll have to order up a new one that is the shorter style. Unless your lifted your hood will interfere with the tall one.
July 23, 201114 yr Sorry to dredge up an old thread but what is difference between the K730 and K 731?
July 24, 201114 yr http://www.jegs.com/i/Trans+Dapt/969/2107/10002/-1 Or search Trans Dapt 969-2107 I used one of these on an ea82. It is a nicer quality adapter than the one that comes in the redline kit. It is somewhat tall and with the tall K&N filter it would rub the hood on the car, with a low profile filter this would be solved (after I lifted the car this was a non-issue). I do not know if the Hitachi pattern is the same between the ea82 Hitachi and the one on your brat, maybe someone can chime in and confirm/deny this. Also, there is no throttle linkage included here, I modified a Loyale bracket to do the job. Finally, this adapter is made for a Datsun, not a Subaru. I did have to massage the bolt holes ever so slightly to get it to fit properly, but it was easily accomplished and successfully installed with no problems. I also believe the design of this adapter better blocks off the little water passage that is below the hitachi (again, on the ea82's, I'm not super familiar with that ea81 setup). Hope this helps someone! I just used this adapter and it kicks rump roast. It is big enough to provide enough pressure over the water crossover (with a little RTV) for no leaks.
