nona Posted March 1, 2011 Share Posted March 1, 2011 You guys were sooo right!! I waisted time and money to rebuild my hitatchi carb. Now I am ready to oreder the weber kit. My 87 brat has EA81 so I think the right kit is the K 730. I thought there was an old post with instructions for the swap. Any help really appreciated. Quote Link to comment Share on other sites More sharing options...
HATCHY Posted March 1, 2011 Share Posted March 1, 2011 When I ordered my weber kit from redline. I recieved a really crappy adapter. It did not line up well, the holes where fine but the inside was crappy and didnt line up Quote Link to comment Share on other sites More sharing options...
obk25xt Posted March 1, 2011 Share Posted March 1, 2011 http://www.jegs.com/i/Trans+Dapt/969/2107/10002/-1 Or search Trans Dapt 969-2107 I used one of these on an ea82. It is a nicer quality adapter than the one that comes in the redline kit. It is somewhat tall and with the tall K&N filter it would rub the hood on the car, with a low profile filter this would be solved (after I lifted the car this was a non-issue). I do not know if the Hitachi pattern is the same between the ea82 Hitachi and the one on your brat, maybe someone can chime in and confirm/deny this. Also, there is no throttle linkage included here, I modified a Loyale bracket to do the job. Finally, this adapter is made for a Datsun, not a Subaru. I did have to massage the bolt holes ever so slightly to get it to fit properly, but it was easily accomplished and successfully installed with no problems. I also believe the design of this adapter better blocks off the little water passage that is below the hitachi (again, on the ea82's, I'm not super familiar with that ea81 setup). Hope this helps someone! Quote Link to comment Share on other sites More sharing options...
nona Posted March 2, 2011 Author Share Posted March 2, 2011 I just ordered the K 730 weber kit from carbsunlimited, should be here Sat. I am very excited to drive the Brat again. Thanks for the info. Quote Link to comment Share on other sites More sharing options...
hatchsub Posted March 3, 2011 Share Posted March 3, 2011 Sorry i didnt see this sooner but... If your carb comes with the 2.5" tall air filter you'll have to order up a new one that is the shorter style. Unless your lifted your hood will interfere with the tall one. Quote Link to comment Share on other sites More sharing options...
Mykeys Toy Posted July 23, 2011 Share Posted July 23, 2011 Sorry to dredge up an old thread but what is difference between the K730 and K 731? Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted July 24, 2011 Share Posted July 24, 2011 One is for the EA81 manifold, and one is for the EA82 manifold. GD Quote Link to comment Share on other sites More sharing options...
Redcap Posted July 24, 2011 Share Posted July 24, 2011 http://www.jegs.com/i/Trans+Dapt/969/2107/10002/-1 Or search Trans Dapt 969-2107 I used one of these on an ea82. It is a nicer quality adapter than the one that comes in the redline kit. It is somewhat tall and with the tall K&N filter it would rub the hood on the car, with a low profile filter this would be solved (after I lifted the car this was a non-issue). I do not know if the Hitachi pattern is the same between the ea82 Hitachi and the one on your brat, maybe someone can chime in and confirm/deny this. Also, there is no throttle linkage included here, I modified a Loyale bracket to do the job. Finally, this adapter is made for a Datsun, not a Subaru. I did have to massage the bolt holes ever so slightly to get it to fit properly, but it was easily accomplished and successfully installed with no problems. I also believe the design of this adapter better blocks off the little water passage that is below the hitachi (again, on the ea82's, I'm not super familiar with that ea81 setup). Hope this helps someone! I just used this adapter and it kicks rump roast. It is big enough to provide enough pressure over the water crossover (with a little RTV) for no leaks. Quote Link to comment Share on other sites More sharing options...
