March 20, 201115 yr '85 Brat, 5-speed D/R (otherwise stock) After a frustrating day trying to find the source of brake fluid loss (and periodic soft pedal), I traced it to the hill holder. When the clutch pedal is depressed and the brake system is pressurized, it leaks fluid like a Harley. Clutch pedal out, no leak whatsoever. The hill holder isn't a necessity for me, so do I A. Rebuild/replace it? Folllowup questions, how complicated is a rebuild and does anybody have a used one they're willing to part with for a reasonable price? 2. Disconnect the cable, add the return spring and hope what's left of the seal holds? 3. Bypass it completely? Please keep in mind that I'm in the road salt belt of the Northeast, there aren't many (none) donor vehicles in the local boneyards. Thanks in advance, Joe
March 20, 201115 yr Had same issue with the 1st '86 BRAT I owned. Disconnected the cable and no more leak, never did repair the HH. Been a few years since I read the post, but I believe it was Skip that said there is just some o-rings in the HH, and they are worn and causing the leak. I have a couple of HH's laying around here, and no use for them. I can send 1 or 2 your way. PM me your addy.
March 20, 201115 yr When I first bought my Brat it was also leaking brake fluid from the hill holder. But since the brake lines run through it, even disconnecting the spring didn't work. I just ended up replacing it with the one from my GL10. EA82 hill holders will fit right on, just so you know.
March 20, 201115 yr Author pm sent, Tom! After a thorough cleaning - and in the light of day - it looks like it's got a slight leak in the open position too. Thanks to all for the input. This forum has been such a huge help. Joe
March 30, 201115 yr No PM from you yet.... May have to do with your post count. You can email your info to me. Use my screen name on here and add, at yahoo dot com. Put hill holder in the subject line.
March 30, 201115 yr Once I found the correct position of the lever so that it leaked no more ...then I tied the lever down with mechanics wire...worked well for many years now..
March 31, 201115 yr I read the manual about the HH a few days ago, so my understanding is that it works to keep the car from rolling back when you first start the car and take your foot off the brake to the gas? I tried it but it still seemed to roll back on my 88GL. Where is it located, if it's disconnected it would be obvious right?
