eryque Posted April 1, 2011 Share Posted April 1, 2011 I'm curious to know what causes that trademark Subaru engine clatter, and how much is okay. I've heard that it's pistons, I've heard that it's valves... My 2.2 in my '98 Impreza only does it when it's very cold, and the sound goes away when the engine is warm. I test drove an '02 Outback last week that was doing it on a 40 degree day. The seller told me that it's normal for a Subaru, but it seemed excessive. Quote Link to comment Share on other sites More sharing options...
1-3-2-4 Posted April 1, 2011 Share Posted April 1, 2011 Those darn short skirts! Quote Link to comment Share on other sites More sharing options...
WoodsWagon Posted April 2, 2011 Share Posted April 2, 2011 My mom's 98 outback is louder than a diesel, doesn't quiet down that much when warm, and has been that way for the last 50k miles. Don't worry about it, even if it's bad, it won't affect how it runs. Quote Link to comment Share on other sites More sharing options...
ericem Posted April 2, 2011 Share Posted April 2, 2011 Those darn short skirts! this forum needs a like button for real! Quote Link to comment Share on other sites More sharing options...
Suba9792 Posted April 2, 2011 Share Posted April 2, 2011 My 2.2 in the 97 does it for about 15sec then it goes away. But it still taps for a while oh say 15 min of driving. Quote Link to comment Share on other sites More sharing options...
danbennett2u Posted April 2, 2011 Share Posted April 2, 2011 To the OP: If it is a steady tick-tick-tick-tick then it is likely from the lifters, very common and not really doing any significant damage but is kind of annoying. Models with hydraulic lifters will do it when they are oil starved (eg cold startup) or when they are plugged. I don't usually think of this as "clatter" though. A "clatter" could be a lot of different things, including timing belt components, etc. Quote Link to comment Share on other sites More sharing options...
nipper Posted April 3, 2011 Share Posted April 3, 2011 Subaru lesson #237 Piston slap. In the good ol days pistons had long skirts. Cylinders are slightly wider at the bottom then the top. The piston skirts helped keep the pistons straight in the cylinder. More mass in thew piston meant more force to move it and a longer time for it to heat up. In modern engines the skirt is almost gone. This allows for the piston to actually shift around in the cylinder and make noise. Once the piston warms up it expnads and the issue goes away. The mass is gone for quicker revving, better MPG and faster warmup. All engines and compressors have some piston slap, some worse then others, and not all of it can be heard. Quote Link to comment Share on other sites More sharing options...
1-3-2-4 Posted April 3, 2011 Share Posted April 3, 2011 heh people always think I'm joking when I say that Quote Link to comment Share on other sites More sharing options...
