April 9, 201115 yr i found the super pro poly part numbers on the xt6 forums, although i cannot figure out the site in the link to order or get a price on these parts. also, i need to know of hand what size swaybar is in the xt6. I at least need bushings for the control arms, radius rod, and front and rear swaybars before i put it all together. so, which website or vendor should i shop for these parts?
April 9, 201115 yr You'll have to find a US distributor of SuperPro. When I bought mine, it was kind of a pain. I believe I went through Modern Automotive Performance here in MN ( http://www.MAPerformance.com ). Sway bars on mine were all 20mm. Although they don't make bushings that will fit under the stock rear straps.
April 10, 201115 yr I've been hunting for some newer, higher performance suspension bushings for one of my cars. Finally decided to make my own by purchasing the raw materials and machining my own. I happen to have access to the best part of a full machine shop, but these materials are soft enough that you should be able to do most, if not all, of the machine work with a hot knife and a power drill. Might want to look into that while you're hunting around.
April 11, 201115 yr sorry to hijack, but hey Miles and Numbchux! I just got a brand new 2000 outback! its got some problems, so Ill be around till I get em sorted
April 11, 201115 yr oh ya, sport compact drag racing at rock falls raceway in wisconsin on the 23rd! you guys should go!
