cracks or casting marks?
cleaned up the heads from my dead engine,and it lokks like there is a crack between the valves on ALL cylinders!
Is this common,or is this a cast mark?
Probably just casting marks. I remember seeing the same thing on my EA81, and thought they were cracks. Turns out they werent.
-Brian
iv'e seen many of those,the ones that are cracked bad will be really clean {preasure wasned w/coolant} iv'e also seen the cracks peened w/ a center punch, to try and fix them??? and the old school test.lay head out side and fill cyinder"head w/gas and time how long it takes to drain out. or not. as i recall if 1/2the gas is still there in 10 min.your good to go. or something like that, the more gas retained the better. good luck todd
