Parking lights won't shut off!!!
99 legacy SUS Had to install a check engine light and sparkplugs,did that hooked the ground on the battery backup and now the lights won't shut off!!Is this a switch problem or should I look somewhere else?
Check the switch on top of the steering column. You may have accidentally bumped it on. Its commonly called the "Subaru virgin" switch.
Yep! It sounds like we got us another virgin here.
:lol:
mysterious parking lamp switch that no one ever sees. It exists to run the parking lights without the key on.
Everyone does it.
Mow, if you marker lies are flashing and wont let you start the car, there is a reset switch near the hood lever(if you have alarm)
mystery switches!
the first time I did it, I was using mcguire's all over my dash and column and hit it. It took like an hour to figure it out. only did i see it because subaru painted the rocker to show red when on!
Thanks everyone,I sang my version of Madonna's LIKE A VIRGIN and promptly went out and shut them off!
