coach9 Posted June 29, 2011 Share Posted June 29, 2011 99 legacy SUS Had to install a check engine light and sparkplugs,did that hooked the ground on the battery backup and now the lights won't shut off!!Is this a switch problem or should I look somewhere else? Quote Link to comment Share on other sites More sharing options...
doc526 Posted June 29, 2011 Share Posted June 29, 2011 Check the switch on top of the steering column. You may have accidentally bumped it on. Its commonly called the "Subaru virgin" switch. Quote Link to comment Share on other sites More sharing options...
Cougar Posted June 29, 2011 Share Posted June 29, 2011 Yep! It sounds like we got us another virgin here. Quote Link to comment Share on other sites More sharing options...
doc526 Posted June 29, 2011 Share Posted June 29, 2011 Yep! It sounds like we got us another virgin here. Quote Link to comment Share on other sites More sharing options...
brus brother Posted June 30, 2011 Share Posted June 30, 2011 Or as Subaru technicians refer to it: Battery Kill Switch Quote Link to comment Share on other sites More sharing options...
johnceggleston Posted June 30, 2011 Share Posted June 30, 2011 Yep! It sounds like we got us another virgin here. no virgin no more!! welcome to the party!! Quote Link to comment Share on other sites More sharing options...
MilesFox Posted June 30, 2011 Share Posted June 30, 2011 mysterious parking lamp switch that no one ever sees. It exists to run the parking lights without the key on. Everyone does it. Mow, if you marker lies are flashing and wont let you start the car, there is a reset switch near the hood lever(if you have alarm) mystery switches! Quote Link to comment Share on other sites More sharing options...
Ricearu Posted June 30, 2011 Share Posted June 30, 2011 the first time I did it, I was using mcguire's all over my dash and column and hit it. It took like an hour to figure it out. only did i see it because subaru painted the rocker to show red when on! Quote Link to comment Share on other sites More sharing options...
coach9 Posted July 2, 2011 Author Share Posted July 2, 2011 Thanks everyone,I sang my version of Madonna's LIKE A VIRGIN and promptly went out and shut them off! Quote Link to comment Share on other sites More sharing options...
97ej22 Posted July 2, 2011 Share Posted July 2, 2011 Lololol ^ Quote Link to comment Share on other sites More sharing options...
