AK_Kev_007 Posted July 29, 2011 Share Posted July 29, 2011 So on my '87 EA82 at idle I have low oil pressure at idle according to the dash gauge. I believe that this has also caused a lifter tick on the passenger side. I think my oil pump is worn out but I'm not to sure. I was hoping for other suggestions before I set out on the wild goose chase. Quote Link to comment Share on other sites More sharing options...
Subarule Posted July 29, 2011 Share Posted July 29, 2011 So on my '87 EA82 at idle I have low oil pressure at idle according to the dash gauge. I believe that this has also caused a lifter tick on the passenger side. I think my oil pump is worn out but I'm not to sure. I was hoping for other suggestions before I set out on the wild goose chase. How low? What pressure do you have when you're driving along? Quote Link to comment Share on other sites More sharing options...
MilesFox Posted July 29, 2011 Share Posted July 29, 2011 Gauge is horiible. Near zero pressure at idle warm is normal. Teh oil pump seal and the cam tower o-rinds would be cause for the ticking, or lower pressure. The oil pump never fails unless it was starved for oil(driving with NO oil) It's an easy fix if you take the time. Cam twer or ings require removing the cam towers, but it's a good excuse for an all around re-seal, do timing belts and water pump at same time. Quote Link to comment Share on other sites More sharing options...
AK_Kev_007 Posted July 31, 2011 Author Share Posted July 31, 2011 (edited) Thanks Miles. As for how low the needle is right above the bottom mark when it is warmed up. And when I'm driving around at regular operating temps the needle moves to "45psi" which is right in the middle Edited July 31, 2011 by AK_Kev_007 Quote Link to comment Share on other sites More sharing options...
el_freddo Posted July 31, 2011 Share Posted July 31, 2011 I would also say that the factory gauges aren't the greatest for giving an accurate reading - but they're good to look at and give you an idea of what's happening under the bonnet. An aftermarket set of gauges would be much more accurate than what the factory instrument cluster displays and will give you a clearer understanding of what's happening with your engine. Cheers Bennie Quote Link to comment Share on other sites More sharing options...
heartless Posted August 1, 2011 Share Posted August 1, 2011 Thanks Miles. As for how low the needle is right above the bottom mark when it is warmed up. And when I'm driving around at regular operating temps the needle moves to "45psi" which is right in the middle This is very normal for the stock guages - not really something to worry about. if your pressure drops while driving, then you need to worry. Quote Link to comment Share on other sites More sharing options...
