September 11, 201114 yr I found an new box of NGKs laying around Plug #BPR6ES-11 Are these fine for an EA82?
September 11, 201114 yr I found an new box of NGKs laying around Plug #BPR6ES-11 Are these fine for an EA82? Yes, that is standard for an EA82. '82 Yamaha Virago 920 runs the same plugs (Tid-bit a info)
September 12, 201114 yr I Use those with the "Y" and it only means that the Spark Plug's Electrode has a inner Shape, Supposed to improve the Spark's Diameter. Just like the Nippon Denso's "U" Groove. Could be just a way to attract the Market too... Kind Regards.
September 12, 201114 yr Could be just a way to attract the Market too... That is probably 97% the reason. You can also run (V-Powers) in the EA82 as long as its the correct part number. Just make sure the shank on any spark plug (Top of the threads to the bottom of the electrode) matches the plugs you take out.
