Clicking sound?
I have a 02 Forestor with 140K miles and have Subbies since 82. The noise isn't the usual when you turn the corner, but on straight away and when going on a curve it goes away. I was able to diagnose outside joints by turning a corner etc. The boots all look OK. Is there a system for us shade tree mechanics for the inner cv joints? BTW at 65+mph it is hardly noticeable and starts about 25. I just completed a 750 mile trip and I cannot detect any indication its getting worse!
It occurs during a moderate acceleration but not during a accelerator backoff. Going around a curve with constant foot pressure it stops. At 60+ it is hardly detectable. I put it on jackstands started engine, no noise under that "light load" or obvious "slop" of shafts when I grabbed the them. The engine was off then. Hope this helps?
I don't know for sure, but my guess is it would be the CV (constant velocity) joint. I have a similar problem in my car and that's what I have determined it is.
  • 2 weeks later...
I replace right cv axle and fixed the problem. Boots looked good and looks to be original. Guess it was inter-joint that was the culprit.
If it is a bad CV joint, you can drive many more miles before replacement. It will just simply get louder as time and miles march on.
