November 30, 201114 yr got an 83 with 13's. its the pesky 4 lug pattern, you know the one thats hard to find.lol. looking for 14" wheels for right now and poss 15's in the next year or so. open minded to suggestions
November 30, 201114 yr If you want bigger wheels you could: - Find some Peugeot 14 or 15 inch wheels also known as "pugs" (make sure you avoid the dreaded metric "390" wheels - Drill out some 6 lug toyota wheels to fit your 4 lug (2 holes fit, 2 new holes must be drilled between the other 4 of the stock holes you are not using) - Buy some allied armnament wheels if you can find a set.
November 30, 201114 yr Author really not looking for anything fancy. plan on a little mudd'n at the most nothing bigger than 15's, and would be happy to stay away from aloy
November 30, 201114 yr Check out the offroad section, there lots of discussions about bigger wheels and tires. I drilled my hubs to a 6 lug instead of my wheels so I can use any 6x5.5 wheel and I think it looks better too.
November 30, 201114 yr Author rille your hubs ay?not a bad idea, did u pull all the original lugs or just add two of the original style.
