stever1000 Posted December 10, 2011 Share Posted December 10, 2011 Hi guys I am kind of desperate, I am selling my '92 loyale and was supposed to have a few people come by tomorrow to check it out. I had problems with my car staying on, advice from this board said it was the alternator so I got it tested and sure enough it was dead. So I got a new one and installed it. The car started up fine before I took off the old alternator, but wouldn't stay running. Now I can't even start it with the new alternator. It sounds kind of wheezy when starting. My lights and everything aren't dim, so it's not the battery (and it was tested before and in good condition) What would cause this? All I did was take off the battery leads and the two wires from the back of the alternator. Any help is greatly appreciated. This is the first time I have experienced this problem in over a year of daily driving. Thanks Quote Link to comment Share on other sites More sharing options...
stever1000 Posted December 10, 2011 Author Share Posted December 10, 2011 anyone have any suggestions?? Quote Link to comment Share on other sites More sharing options...
6 Star Posted December 10, 2011 Share Posted December 10, 2011 Try charging the battery? Even though you have enough juice for you lights/electronics to work, it may have ran too low to power the starter. Quote Link to comment Share on other sites More sharing options...
Indrid cold Posted December 10, 2011 Share Posted December 10, 2011 (edited) It usually fails... Alt or Battery first, seems one takes the other out, then since your broke anyways something else usually jumps in like the ignition module.. or ? 92 Loyal, which motor is that.. EJ or EA ? If it's EA then check the usual, rotor screw loose and not turning, no spark, fuel? fuse? EJ., no idea... YOu wanted ideas... that's all I got... Edited December 10, 2011 by Indrid cold Quote Link to comment Share on other sites More sharing options...
stever1000 Posted December 11, 2011 Author Share Posted December 11, 2011 I'll try charging the battery and see if that helps Thanks Quote Link to comment Share on other sites More sharing options...
TomRhere Posted December 11, 2011 Share Posted December 11, 2011 If charging the battery doesn't help, it could be the battery cable ends. I've had a few issues with them failing after unhooking them from a battery. Especially with the "molded on' ones. Have pulled those apart with little effort. Quote Link to comment Share on other sites More sharing options...
stever1000 Posted December 12, 2011 Author Share Posted December 12, 2011 I had the battery checked and it tested fine, the guy recharged it and gave it back to me at the end of the day. I put everything back together and tried to fire up and still nothing. I tried a few more times, and still nothing. By the fifth or so try, I floored the gas pedal and it started to respond. I tried again giving it more gas and it fired up, idling rough. I turned it off and started again, and it fired up again. It idled at 2000rpm for a while, so I turned it off, started again, and it lowered the idle. It seems to be running fine now, but why did I need to floor it to start it? It had been sitting for 3 weeks, maybe something setttled in the fuel lines? Should I change the fuel filter? Thanks everyone! Quote Link to comment Share on other sites More sharing options...
SoobDood05 Posted December 12, 2011 Share Posted December 12, 2011 Sounds like you may have flooded it, Or you got a fuel filter thats clogged, or if you ran it out of gas it coulda sucked up rust and scale causing it to clog the lines? just a couple suggestions. hope it helped. Quote Link to comment Share on other sites More sharing options...
