February 7, 201214 yr good ay so l just did the oil seals and timing belts (EA82)(92 loyale) cuz of a massive oil leak which is all good now looks like l should have done the oil pump seals too cuz there is a super minor leak which appears to be from there (though the oil level hasn't dropped according to the dip stick) any way thats not what this post is about there is another leak either out-of or on-to the passenger cv boot it splatters on the fire wall and muffler (or whatever part of the exhaust system is right there) but l can't figure out what it is or where it could be coming from :-\ my best guess is the transmission so l went to check the oil and the dip stick is broken (the handle is there but not the dip part) l'll get one when l get a chance but for now could some one measure their tranny fluid dip stick to tell me how long it is and how far apart the fill lines are so l can check it thanks goat
February 7, 201214 yr How about the CV joint? Easiest way to tell is clean the arear then take the car for a moderatly long drive and check it. Check the tranny lube level too.
February 7, 201214 yr Author well it does seem to have something to do with the cv joint and l cleaned it and drove it and it seems to splatter from the cv joint but the boot seems fine l cant find a hole and isnt the cv boot full of grease? would it be melting or something? also l would love to check the tranny fluid but my dip stick is broken hopefully some one will measure theirs so l can aproximate thanks goat
February 7, 201214 yr Was the grease already there from a previously spit axle boot? Maybe the axle was re-booted and a little overpacked with grease. Excess grease can work past the boot clamps. Try to clean it up and see of more occurs. I wouldnt worry too much about the axle if the boot is not ripped, as it is worse for dirt and water to get in than for a little grease to come out
February 8, 201214 yr Axle grease is obvious. It's really black, sticky, kinda smelly, nasty grease. It'll get on your hands and not want to wash off. If you say what kind of transmission you have, it'll help you get the right measurement.
February 8, 201214 yr There's most likely a small hole or crack in your CV boot . I have one in mine and it's spits a little grease on the firewall and Cat ( catalytic converter ) . Squeeze the boot and listen for air coming out or like a slight whistle and move you car back an forth to find the hole . It's not really a big deal until you hear the joint start clicking when your driving .
February 8, 201214 yr CV boot is very likely. You should be able to tell by what's been slung onto the firewall and exhaust. Grease will be pretty obvious if you run your finger over it. However, it could also be oil. A few weeks ago was riding with a friend in his Outback, smelled something burning. Peeked under, saw smoke comin off the cat right behind the CV. Figured it was a torn boot, but didn't see a tear. Then noticed that there was a bunch of motor oil pooled on top of the engine. Turns out he'd been adding some oil earlier and the wind had blown a bunch onto the engine. So it's possible that there's an oil leak higher up, but it's probably the CV. Edited February 8, 201214 yr by Cyfun
February 8, 201214 yr Author it does seem like axel grease black and sticky there was alot of it on the cross member and l wasnt sure if it was from the previous oil leak (got the car with the oil leak cuz the po didnt want to deal with it) and l pressure washed it the fire wall and cat stayed clean till it got driven cross state then then towards the end of the drive there were weird swishing sounds and when l took a look new splatter l'll look harder at the cv boot (and probably ignore it til it starts making dry noises) l dont know which tranny it is 5 speed manual l'll look for numbers next time l get a chance (it's my lady's car now) thanks goat
February 9, 201214 yr Not a dual range? That's what I have, so I'm not sure the dip stick is the same length between the two.
February 9, 201214 yr Definitely sounds like CV grease then, probably that inner boot. Jack the car up so the CV is at a steep angle, and rotate it, looking carefully for a crack. Or it could be coming out of the end if it's missing a band.
February 15, 201214 yr Author yep cv it is found the leak cleaned it and attempted patching with RTV we'll see if it holds if not l suppose l'll try a split boot any recommendations? also as per my other question about the missing trans oil dip stick the numbers l found on the trans are as follows 464794 AW-TW75F5A2BV so if soemone with the same trans would measure their dip stick and the fill lines that would be great thanks goat
February 17, 201214 yr See if you can place something ... Stabilize it... such that it is behind the head and in front of the shaft..... Like a piece firm card board.. wire it in so it obstructs the shaft from the head... THe idea here is so you can determine where this slop is spitting out.... Could be the head gasket.. On the passenger side.. the oil o-ring is on the fire wall side of the head.... These love to squirt oil out.... so the cardboard will get squirted on, on the head side of the card board..... and on the axle side it will be clean. (if it is the o-ring in the head gasket) if it is the axle, the axle side of the cardboard will have the slop on it.... Yeah, and axle will sling grease out of a tiny hole in a boot.( I got one doing it right now)... and the head o-ring.... will shoot it out while driving..... (like a spray gun)
February 17, 201214 yr if not l suppose l'll try a split boot any recommendations? Split boots are junk. A new boot is only about $10 and isn't horribly difficult to install. But I usually just replace the whole axle when I do, and get an axle with a lifetime warranty so that if the boot ever tears, whole new axle! See if you have any luck with silicone or other patching methods. Maybe try a bike tire patch kit and glue, cause silicone doesn't always stick well to rubber. I've heard people have had luck just with vulcanized glue. But if you're going to spend more than a few bucks trying to bandaid the problem, might as well replace the boot.
