April 8, 201213 yr The (split) ring seal I need to identify (so I can re-order it) is pictured as #10 in the the 1995 Subaru Legacy AWD PDF -- "Section 3-2 1. Torque Converter Clutch and Case" (cut/paste link below to download the PDF). I can't identify it on opposedforces.com/parts. Any chance anyone knows how I can get the id number? I have called 2 Subaru dealers and they can't help me. Thanks, Rob http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=9&sqi=2&ved=0CIwBEBYwCA&url=ftp%3A%2F%2Fftp.caravan.kz%2FPub%2FAuto%2FSUBARU%2FLegacy%2F1995%2FService%2520Manual%2FTRANSMISSION%2520AND%2520DIFFERENTIAL%2520SECTION%2FAUTOMATIC%2520TRANSMISSION%2520AND%2520DIFFERENTIAL%2FMSA5TCD95L5573.pdf&ei=vaOBT9vkA6rg0QHn6_zqBw&usg=AFQjCNFsaqoMwb6qTSF3cYbTCYQs1WLICw&sig2=Y4k3ejDQ2pyShSKwjCxDfg
April 8, 201213 yr Author I can't see that this part is individually identified with it's number at opposedforces.com/parts. There is a listing for the contents of an entire gasket set for the trans -- it's probably listed there, but not unambiguously. I'd rather not order the entire set just for this one single item ...
April 8, 201213 yr Part number 31361AA000 should be the correct part number for the seal you're looking for. I happen to use Opposed Forces a lot at work so I know my way around it. Hopefully that's what you needed!
April 8, 201213 yr Author No, that's the main seal -- #15 on that diagram. I need the tiny split run seal on the oil pump shaft, #10 on that diagram ...
April 9, 201213 yr item #1 - ring-seal - impreza http://opposedforces.com/parts/impreza/us_g10/type_9/automatic_transmission/at_torque_converter_and_converter_case/illustration_3/ item #1 - ring-seal - legacy http://opposedforces.com/parts/legacy/us_b11/type_6/automatic_transmission/at_torque_converter_and_converter_case/illustration_3/
April 9, 201213 yr item 15 in your pic is item #12 (15 in later years) in the link below. find the part in the diagram and follow the numbers to the box to the left. http://opposedforces.com/parts/impreza/us_g10/type_9/automatic_transmission/at_torque_converter_and_converter_case/illustration_1/
April 10, 201213 yr Author After reviewing johnceggleston's remarks -- I think I may owe Caboobaroo an apology -- he had it right all along -- I believe it is indeed part number I need -- 31361AA000 (just under $10 from World Impex). I've ordered it and I'll post back if that isn't correct (so that this thread will make at least some sense to the next guy wallowing in confusion over this). Thanks all -- And those links to the timing belt work will come in VERY handy -- next thing on my list ... Rob
