ShawnW Posted May 16, 2012 Share Posted May 16, 2012 I have never had one do this. I am thinking AWD clutchpack failure. Seems to mostly go away with the FWD fuse installed on the 4EAT transmission. Quote Link to comment Share on other sites More sharing options...
nipper Posted May 16, 2012 Share Posted May 16, 2012 Not exactly sure what you are trying to describe here. Quote Link to comment Share on other sites More sharing options...
ShawnW Posted May 17, 2012 Author Share Posted May 17, 2012 The car actually pulls to the side when it shifts, sort of like a brake caliper hanging. It actually kindof swerves! Quote Link to comment Share on other sites More sharing options...
nipper Posted May 17, 2012 Share Posted May 17, 2012 Ok this is interesting. How many miles. That sounds more like something loose in the front end, a loose engine, first thing is get under the car with the wheels off the ground (not running) and inspect everything. Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted May 17, 2012 Share Posted May 17, 2012 Tires? Accident damage? Bent/loose suspension parts? Loose nut behind the wheel? :-p Alignment specs would be interesting to see. What about axles? Quote Link to comment Share on other sites More sharing options...
nipper Posted May 17, 2012 Share Posted May 17, 2012 Sounds like to me something is really busticated. My fist thgout too was "when was the accident" Quote Link to comment Share on other sites More sharing options...
Caboobaroo Posted May 17, 2012 Share Posted May 17, 2012 Check the lower control arm bushings. They may look good but I'm willing to bet the rubber is starting to split and they will puke the oil out shortly there after. Quote Link to comment Share on other sites More sharing options...
fixingrusinc83 Posted May 20, 2012 Share Posted May 20, 2012 Shawn Have seen before think it was bad DOJ Mike. Quote Link to comment Share on other sites More sharing options...
