best way to drain fuel tank
There is a drain plug in the front right of the tank.
see:http://www.main.experiencetherave.com/subaru_manual_scans/2000+_Legacy_FSM/
O.
Just a flanged bolt. probably 12/14mm.
Part#901000188
O.
ok, seems to be different or looking at the wrong bolt, thanks
  • 12 years later...
Can I use the fuel lines under the hood to drain fuel tank on Subaru outback 2006 I know I’ll have to find the relay and put something across it to keep pump going
  • 2 weeks later...
Can always use a siphon pump or a drill operated pump.
Hit the junk yard and get the car side of the fuel pump plug and a foot or so of wire.  That way, you can hook the pump right up to a battery.   Since it's a saddle tank, it will not pump out the driver's side of the tank.  Only way to get that side is to pull the sending unit and siphon the gas out.
