June 6, 201213 yr Okay so Thanks to The FNG with his pdf (that has pictures) of the repair manual's guide to changing out front wheel bearings I'm going get rid of the progressively loud roaring in the front. Anyhow's I'm stuck between what bearings to get http://www.fastenal.com/web/products/detail.ex?sku=4126203 http://www.fastenal.com/web/products/detail.ex?sku=0474397 Both are double sealed "2RS" although the second one has speed rating of 11000 rpm compared to 8000 rpm. The only other difference I can find is one says it's radial ball bearing and the other says ball bearing. Late Edit: I forgot to say it is 1986 4WD GL Wagon Edited June 7, 201213 yr by chaseman
June 7, 201213 yr Author Yeah they're the only bearing supply (apart from spendy part houses) in my town and I'm wanting to go for a sealed bearing. Well I usually love rock auto but it'll be cheaper with fastenal. Plus I'm not sure if you could get the sealed bearing from rock auto.
June 7, 201213 yr Mine are like the first ones with the black rubber seals. I got them from Mcguire Bearing and cost me $8 a piece and some change. They've seen lots of abuse turning 30" mud terrains on the trail and freeway and are still holding up flawlessly. You willn't find sealed bearings at any auto store like rockauto, napa, carquest etc..you have to go to an industrial supply/bearing supplier. If you decide to get normal unsealed bearings get them at the same place. Last I checked, unsealed bearings for a subaru run about $5 at Mcguire Bearing compared to $15 at rock auto and $40 at napa. Josh
June 7, 201213 yr There any chance you can snap a photo of the order of assembly for everything that goes on the axle stub before the castellated nut? Need to know in what order things go back on there now that I have the cone washer my car has been missing..
June 7, 201213 yr Author I don't have it apart quite yet , I do have a pdf of the whole process with pictures that the The FNG sent me. Pm me your email and I can send it to you.
June 7, 201213 yr Author Also another note on those bearings , I think the picture may be wrong for the bottom link cause it says 6207 2RS which I though was double seal while there would be Z's in there for shielded ones like the picture. I dunno
June 7, 201213 yr what kind of soob!? im assuming ea82, i bought my sealed bearings on amazon of all places, 7 a piece free shipping. they are chiners tho
June 7, 201213 yr Author Whoops , I forgot to put that . 1986 Subaru GL 4WD Wagon I edited my top post too
June 7, 201213 yr I don't have it apart quite yet , I do have a pdf of the whole process with pictures that the The FNG sent me. Pm me your email and I can send it to you. PM sent. Thanks!
