When Removing Mech Fan...
When you are removing the mech fan do you put a pully inplace of the fan pully that was there?
Or could you just use a smaller fan belt?
Well-if the pulley runs the water pump--no pulley = no cooling. I'd put real short bolts in the pulley (remember to use blue locktight on them;) ) & put a new belt on
if your just removing the mechanical fan to make room for a electric one or waht ever
the mechanical fan actually bolts on top of the water pump pulley so they are 2 seperate doohickys
just take off the fan use a few washers to equal the thickness of the fan hub and put your old nuts/bolts back on to keep the pulley in place and there ya go
no need for a new belt or anything
Actually, when removing the mechanical fan, if it's attached to the water pump, you can just turn the studs around in the mounting flange and bolt the pulley right back on.
What do u mean that?
Could you please explain that again?
I got a spare one sitting under my house and I have just had a look at it but couldn't get the pulley thing off the rod after unscrewing the fan and alliminium cap. This is because I could get the second bigger "U ring" (i think thats what it called) out with my plyer thingies.
And yeh the belt does run the water pump.
Hmmmm, I've never looked at an ea81 mechanical fan before. They may be different.
On my ea82, the flange that's attached to the water pump has four studs that screw into it. The pulley goes on these studs, then the fan, then the nuts. I normally take off my mechanical fan during the winter, and I just take off the nuts, take the fan off, then the pulley slides right off. Unscrew the studs and turn them around so the shorter side now faces out, put the pulley on, and tighten down the nuts.
nah the fan has a pulley seperate to the alt but the fan unit has the alt mounting on it
with out the fan pulley i think the belt wont be tight enought
i could take some photos tomorow if that could help
