March 19, 201313 yr Author I'm lucky I have a nice neighbor that is going to help me, he is a retired welder fabricator and he has the steel, the tools and the knowledge to fix it. I just have to do the prep work and trade material for grunt work, that's no biggie for me. Edited March 19, 201313 yr by mikaleda
March 21, 201313 yr I would like to add that only boner county salts the roads.The rest of idaho uses gravel.
March 21, 201313 yr Author That figures bonner county is the cheapest county in Idaho, two people have already gotten stuck on the county road because the ruts are so bad and so far nobody's doing anything
March 24, 201313 yr Author So I'm going to be getting some Peugeot rims from a neighbor in a couple weeks. I have a choice, I can get alluminum alloy or steels both are 14's. I'm thinking of getting the steel rims since I want this to be mud rig but, I like the looks of the alloys. I'm torn on wich ones to get
March 25, 201313 yr Author Okay I flipped the strut tops around since I found I had them in backwards and that helped with the binding I was having. I fixed the overheating problem that I was having now it rides just a hair above where it used to but that's not a big deal. I have the heater core disconnected since its missing the valve and I have the old V.R. Holding the seat up. I will be taking this down to the neighbors today and see what we can do to fix the floor boards oh and I'll try and get some pics of the under cairage.
March 26, 201313 yr Author picture update undercarriage i just found this today as i was breaking loose the bolts on the rear end to do the bearings (which i successfully did) it doesn't seem to make my tire sit funny but, i'm afraid to try and straighten it out in case i can't get the bolt holes lined up again.
March 28, 201313 yr Author Well I got the ps bearing apart and out having a hard time getting the new race in, I'm going to have to take it down to the neighbor that has a press and press it in. Fun fun fun until daddy takes the gl away just a little stab at humor there Edited March 28, 201313 yr by mikaleda
March 28, 201313 yr Wow man thats a hell of a bend. Pm me if you need a replacement. I'll send you one for the price of shipping.
March 28, 201313 yr Author Wow man thats a hell of a bend. Pm me if you need a replacement. I'll send you one for the price of shipping. Sweet thanks. When I get a little money saved up I might just do that.
April 2, 201313 yr Author Update; I got the P.S. wheel bearing in and it seems to be doing better, but I could not get the D.S. axel nut off. Damn thing is seized on there so bad I was afraid I was going to break the 3/4 inch breaker bar I borrowed, I had a 4 foot cheater on it, jumping on it (I weigh 260 lbs) and it wouldn't budge at all.
April 2, 201313 yr i use a a wrench whatever size the axle nut is with a 8ft crow bar then i get it so the crow bar holds the hub in place then i put the wrench on and give it a few hard quick stomps with my foot, somehow this has worked great for me everytime but i have a filling its rusted on. have you tried tightening it to make it break loose?(i wouldn't sugest that but i have done it a few times if it will not loosen). spray it with something good that will penatrate rust and that will help you hopefully.
April 3, 201313 yr Author Ya I've tried tightening it a little to break it loose, it wouldn't move. I even got it as hot as I could with my p.o.s torch and tried, but I got nothing. My last resort is taking it down to the neighbor that has cutting torches and have him heat it up red hot and try and break it loose while its still hot.
April 3, 201313 yr If your torch is like mine... and uses a small propane bottle, you could get a bottle of mapp gas (yellow bottle). It burns ALOT hotter than propane. Just a suggestion. Hope it helps. Ron W.
April 15, 201313 yr Author Bump! And I found out why my front end is making noise, it's bad bushings on the stabilizer bar? I guess that's what you call it, but I was crawling around under there and grabbed one and heard it clunk so I checked them out and their definatly hard and deformed. Not sure when I'm going to fix those, but I'm not in a hurry.
April 15, 201313 yr is it the sway bar from side to side of the car or the strut rod from under the passenger compartment to the lower control arms?
April 15, 201313 yr Author Sway bar that's what it is I think, should be fairly easy to do them. I'm not to worried at the moment since I just tried driving this car to town and my pos cheapo Stant t-stat started messing up
April 15, 201313 yr Author Also I found out theat my oil pump hasn't been filtering the oil since before I got this car so this p.o.s ea71 is going to get thrashed when I go mudding in the near future. Ea81 and a dual range trans is in the future for this car, along with rear disc breaks.
April 20, 201313 yr Author Okay, I found a parts car with a good ea71 and single range trans, so this car should be getting a transplant soon. This ought to put it back on the road again
April 24, 201312 yr Author Yay, I got my parts car, it has an ea71 with Hla's and a good single range trans, it even has nice drivers side seat! What a score best $100 I've ever spent. And with that I'm going to bed because I smashed my wrist with a 2x10 loading it on the trailer. I'll get some pics in the morning.
April 24, 201312 yr Author I love my new drivers seat what a score, I also scored another set of thirteens and a set of fourteen steel rims, new engine looks clean and new trans seems to be in good shape. I've already started swapping parts, I now have a drivers side mirror again and a new heater with control valve I can hardly wait to start working on my wagon. I'm going to start up the new motor tomorrow if a get a chance and check it out, get it ready to swap in. Weird thing about this motor is it looks like a Hal block but an 80 manifold with a seventys coil and distributor I'll look more into it tomorrow
April 24, 201312 yr Author Okay here's a pic of my new parts car, I started it up and it runs, but since it doesn't even have headers I didn't let it run long. I'm going to put it in my car and I'm going to change the distributor so It matches my coil and so that I have electronic ignition, I hate points.
April 24, 201312 yr Author Ya I was surprised how nice it was, I would try and fix it up a little and make a little offroader with it, but I'm not allowed to keep it. I hate scraping one of these older subies, but at least the parts are going to a good cause.
