August 6, 201213 yr Hey all. I found this Intake tube that fits my '01 Legacy L 2.5 and I have some questions. Would this pipe have a higher diameter than stock? And what would I need to hook it up to a Greddy Airinx Universal Filter? http://www.thepartsbin.com/catalog/?N&uts=true&Ntt=REPS315502+2000+Subaru+Legacy+Intake_Tube+Bolton_Premiere&tpbSuruintusubarulegacy20002001boltonpremierereps3155021547005&tpbsendcid=tpbfroogle Filter: http://www.vividracing.com/catalog/greddy-airinx-replacement-element-blue-universal-p-22894.html?utm_source=googlebase&utm_campaign=googlebase&utm_content=6925 Thanks, WRX
August 6, 201213 yr dig around here for some dimensions/info http://www.greddy.com/products/airinx/airinx-parts/
August 8, 201213 yr Author which size would fit? that's all I ask. Do you think that pipe is 3 inches? Does it matter which size filter I get to fit the pipe? or is it just the size of the filter itself? Edited August 8, 201213 yr by WRX
August 8, 201213 yr I just don't know, sorry. If it is, 80mm should be good (figuring in wall thickness)
August 8, 201213 yr maybe email the suppliers. Or search/ask over at NASIOC. There's no end to the mods those guys have tried.
August 8, 201213 yr Author I did the stupid live chat thing and the guy wasn't helpful at all. I was like "I just want to know the diameter to determine if it will fit what I want to do, and he just asked the same questions it asks when you order it. I wasted about 30 minutes talking to it. I'll try NASIOC. Thanks.
August 11, 201213 yr Why are you wanting an intake in the first place? There is no performance to be gained here.... GD
August 11, 201213 yr Agree. Subaru's design pulls the coldest air in from the outside. These usually pull hot air from the engine compartment. The only upgrade I have seen is a clean K&N or Perrin washable filter dropped into the factory air box and that's only if its serviced properly and the car is Turbocharged and tuned for it.
August 13, 201213 yr Would I need an MAF adapter? No, 2001 2.5 SOHC uses a MAP sensor instead of the MAF sensor. The only way you will get almost as cool of air to your intake running that setup, is to have your cone filter installed INSIDE the wheel well. Any air drawn from the engine bay is gonna be ~30F+ warmer than outside the engine bay.
