August 6, 201213 yr Ok, so, I have an 87 RX and a shop replaced my distributor and they apparently had "a Subaru 1800 distributor out back" and put that in. Its been running...more or less now for about two years. I went to look into its misfire/stuttering problem further when i noticed the part number was 22100-AA440. Everything i find in reference to that number is a GL-10. I would like to know if its the right one, a new one says the part number would be one of these: 22100-AA450X, 72649003781 Is the random site i pulled those numbers from full of crap? are these distributors different at all? the full list of numbers is: 22100AA440 D4P86-03 A A703 do i have the right distributor?
August 6, 201213 yr All optical distributors are interchangeable. If it runs then it's the right one. /Thread. GD
August 7, 201213 yr try swapping in a different coil, I had simular disty swapping going on and then solved the stumble with a coil, just 2cents, good luck...........G
