August 12, 201213 yr 2001 Forester, 170K miles, greatly loved by our family. Has a problem with temp gauge and ? Head gasket replaced in 2003, along with water pump. Belts look normal. Coolant has not been flushed in a couple years, this car isn't heavily driven. I checked messages and could not find similar problem with our symptoms. On a hot day this week (over 100 deg) Forester temp gauge went up a couple notches from normal with the a/c on while going up a hill in our Sierra Nevada neighborhood. Temp gauge returns to normal when I turned off a/c. Coolant level was OK, added a little water. Oil level was 1/2 qt low, added oil. Fan operates fine. Drove it again early this morning and gauge reported normal while going up country. Came back downhill. Temp gauge notched up again when I returned uphill again at noon, and yes, it's hot as heck again today. Temp gauge never got close to red area. We will test the thermostat, other advice?
August 12, 201213 yr take a look at the radiator itself, maybe it could use a good blasting with a hose to clean out bugs. testing the t'stat is a good idea, but it's at least 9 years old. they aren't pricey so, go ahead an re-install a new one. from the dealer or, a Stant Xacstat 48457. the one you remove BETTER look like;
August 12, 201213 yr That is good advice; Also I also install a new radiator cap on our Forester about every three years. Cheap insurance to me.
August 12, 201213 yr Author checked for flying critters, cooling fins are clear. When it cools down we will dump old coolant. Should we flush with water? Then we'll add new coolant. Thanks for all the help.
August 12, 201213 yr Author also, thermostat is an original Subaru part and it's already wide open by the time the temp is up a few notches. We're also not seeing any engine codes.
August 12, 201213 yr also, thermostat is an original Subaru part and it's already wide open by the time the temp is up a few notches. We're also not seeing any engine codes. hmmm, I dunno, this is disconcerting. Um, when you refill the cooling system, you will probably want to know about 'burping' (making certain there's no trapped air) if you don't already. do a search here as there may be 2-3 approaches. In any event, you will want to monitor the level in the overflow tank after the first 2-3 drives just to make sure the system is full. In the future - if it begins to look like a serious overheating event, turn the car's climate control to full heat - it may buy you a little time to exit a freeway or get to a safe stop.
August 12, 201213 yr Author Took it for a spin just now. Cannot see any obvious leaks. Will ask our mechanic buddy to do a pressure check tomorrow.
August 12, 201213 yr Author thanks for the advice about the flushing and burping. We probably should have taken care of flushing it awhile back.
August 12, 201213 yr Took it for a spin just now. Cannot see any obvious leaks. Will ask our mechanic buddy to do a pressure check tomorrow. Probably a good idea - hope it's something simple.
