EA to EJ swap harness
General Disclosure use to do them im not sure if he still does, i think sjr is doing them?
If its OBD1 I could do it, BUT you would be my first customer, i did mine not to long ago and it runs great. Ive seen people charge 250$ for the obd1.
Prwa AAE
A "merge" is different than a "strip". You need two harnesses for a merge - is that what you are wanting done?
I strip them for $200 on OBD-II's and $250 on OBD-I's.
A merge will be based on what two harnesses I'm merging.... the cost is generally around double the price of a simple strip.
I was in fact referring to a merge. I'd have the harness from the 90 Loyale and the harness from the 96 Legacy, and I'd want them merged. This won't be immediate though.
