my lifted subi
godspeed trailing arms and lateral links ...check
1604688_787238657986253_191394703118218310687008_787296161313836_48048745190900010376274_787238634652922_830862631278702
  • Replies 148
  • Views 25.3k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • finshed the roof rack paint ... ta da
  • after aproximantly 3 '' lift from 04 forester xt struts puddle fun i had to cut my fenders for this 215 75 r 15 with my new snorkel and cheap summit racing rims $45 3.75 backspacing and whe
Posted Images
replaced and painted those flimsey a arms or control arms
Join Date Feb 2012 Location big bear Posts 410
1526983_789476327762486_290317046199793310665713_791020827608036_41795248905135210340010_789389697771149_17334686347747810347228_789476297762489_192190570108019
finished flipping and making brackets for the carrier bearing
10006266_797920236918095_742509909529213
and yep!!!!!
thats where we made the bike rack!
10659427_787823811261071_71958024434355410710866_787823714594414_60980854839270310436312_787823784594407_585945147249304
Looks great. Also looks like you've got some awesome terrain out there to go and tear up.
Sorry, i meant the spindle that the entire spare tire rack rotates on. I was wondering where you bought it from.
seems like i have left this page in the dark
well yes i got the tire mount idea from northcoast ..
but i didnt like how the trunk had to be smashed in ...so thats why there is space but have no fear
for that space will be filled with extra gas cans at some point ,
and as for the hub im not sure i understand the question ...
if you are asking where the tire sits and bolts its just a piece of metal circled and drilled out ..with lug studs welded too..
Tire mount was all Monstaru.  The trunk didn't have to be smashed in.  That was just body damage from getting rear-ended by a larger wheeler.
I do like the latch system better.  Might have to figure a way to incorporate that.
Nick... the reason it looks like the gap is bigger is because it's mounted higher.  Same vertical plane but my hinge point is about 6" lower.
so it was the all famous monstaru..... :D oops..
either way it was genius....i thought the trunk was purposely smashed to sink the tire in .. :huh:
i noticed an imediate diffence between the two ..but i guess the 6'' drop explains that..at first look i was ify of the space on mine but it didn't last long
once i day dreamed & pictured a few extra gas cans and starred at the car every second of the day i like how it turned out...ALLOT
 ..the extra gas cans is gonna be interesting ..i have an idea B)mwahahahaha ..but u guys gotta wait and see ..its going to be very interesting and new
(to the best of my knowledge)..on how im going to incorporate them into the car ...
i want to give another HUGE shout out to james from R-LMotorsports.com
he has been alot of help since day 1 ...
scooner im gonna have to do some digging
northcoast .. i read back on my thread ..
i was  giving a shout out as to which Subaru had inspired me to do the rear tire mount/rack ..and that happened to be your car..i like to try and put credit
where it's due ..i believe yours was the first if not only tire mount/rack i've seen ..unless i mixed up the two of your cars somewhere between hours upon hours of cyber world research on subies , and whats new here and there ... cheers!! :headbang:
where it's due ..i believe yours was the first if not only tire mount/rack i've seen ..unless i mixed up the two of your cars somewhere between hours upon hours of cyber world research on subies , and whats new here and there ... cheers!! :headbang:  [/quote
That is the same tire mount.:)
I threw that together one day When I had some time, with what I had laying around. It coast me zero dollars to produce . If I were to do it again, I would by a latch for it, and use a replaceable bearing swing out. But for my first one , I think it turned out ok.lol
yours and northcoast is the same tire mount?
as in not similar the exact.. like pulled off one car and put on to another same ?
or just same desighne differnt rack?
no... exact as in I purchased the shell with the tire mount on it and rebuilt the car.
  • 2 months later...
ok ok ok ok ok finally got the rear tire rack off for long neede rust removal and paint so i figured id snap some pics for better detail so heres how the rack was done for you interested people!
hope these pictures explain most everything!
10933821_848065785236873_17026808583319210917854_848065845236867_44665165559168410933751_848065825236869_12772867272372610933953_848065801903538_60977251292773210013848_848065861903532_21791848962786315922_848065898570195_21806190252556722910933897_848065921903526_2932029909193471743485_848065948570190_33457137724622439801_848065968570188_455775398945400654410933821_848065785236873_17026808583319210403345_848071941902924_83782928785328910685356_848072071902911_4424781924191608991_848072591902859_426314052011746232810492120_848073471902771_768095952768735
Nice, good detailed pics! Your car is something else man, i really love its rawness!
thank you ..
so i got the rack off and i pointed out where and how i mounted it ...i hope this is enough ! it will be painted soon ! so stay tuned ! you can see i already started some rust repair! the electric has a quick release .. and if you look closely at the pic with my three fingers pointing at the three mounting points for one side youl see that the front two are tilted down ...when you make this only then you will find the correct angel of the mount brackets1901276_850382775005174_555471106502786610930951_850518134991638_60304192975301110881664_850518148324970_57015860977529710474191_850518164991635_55602030516834810941844_850518174991634_39346206388600910929970_850518188324966_2059985936318951601601_850518201658298_476275825426163910924702_850518238324961_265764625946218
10943026_851879411522177_73478790877102810931004_851879314855520_11105145259351210620772_851879654855486_91167778010782010470809_851879691522149_70617712180633710930920_851879244855527_10973430690426110926368_851878088188976_75447923862842710391403_851879891522129_30555528263144310676375_851879934855458_17902664154916610947228_851880038188781_78097438698120910950729_851880174855434_407899263200031ta da
Lookin good! How much does that rack weigh?
  • 3 months later...
