1983 ea81t gl wagon build
Wow you have been busy. That is going to be sweet ride when your done.
yah its going to be a nice ride when done, somebodies going to love it when im done building it ;). once im done putting it together, getting all the stuff done at dmv, going through deq, getting tags, and driving the thing abit its going up for sale if only it were a 2 door sedan or brat :(. the only thing it will really need when i let it go will be a paint job, the rear quarter pannel have a little bondo, and the passenger fender bent back to shape at the bottom or get another one.
  • Replies 90
  • Views 16.6k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • turbosubarubrat
    turbosubarubrat
    She needs a good cleaning look at the dash. Was my last resort since i couldn't find the right filter wrench and was too tight to take off by hand. Hopefully get the oil pump seal on tomorrow and re
  • turbosubarubrat
    turbosubarubrat
    Mount stud stripped out so welded it up, ground it down, then threaded. Skid plate and guards installed.
  • Well thats one way to do the towing lights
Hopefully you get to have a little fun in it after all that work ;):burnout::banana: :banana:
went to the junkyard today and got a factory radio with both connector sides plus the shifter cover and radio cover combined for $25 with 2 plastic pieces :) and i got the radio installed and it works great i just had to wire it in. also i got the rest off the off the mounts bolted on for the motor/tranny plus i got the streering wheel hopefully aimed right :Flame:
2/10/13
86 xt-6 turbo wiring distribuator harness
17679_254706737997805_2048389083_n.jpg2/11/13
285243_254706814664464_441065701_n.jpg66713_254706861331126_1237347746_n.jpg527985_254706897997789_1251582244_n.jpg17694_254706937997785_1780788822_n.jpg60723_254706981331114_280231738_n.jpg2/12/13
switched wheels and tires. for two reasons the tires where old and weathered and i want the rims
17015_254707287997750_1027384422_n.jpgalso did a seat swap. had these in my brat but blue looks better with blue instead of tan and blue.
went to two junkyards today and i got a spare rear defroster switch, the hard plastic piece that is by the seat belt for the drivers door, and turbo lines. for the brat got a new sigaret lighter(well old but has never been used so is shiny even where the sigaret is put to light), factory radio, spare third eye :D , and a brush guard B) . also got a subaru embelm off a 4 door sedan that has the hole for the key to go through thought i can sell. probably going back tomarrow to get a chrome bumper for the brat too.
2/17/13
stripped down the distribuator wiring harness and cut it down to fit
541526_259982294136916_2038767350_n.jpg529944_259982360803576_1233394776_n.jpg533103_259982407470238_483382710_n.jpg557928_259982447470234_1980585253_n.jpg581868_259982504136895_378118807_n.jpg
2/24/13
got a plastic piece and turbo lines. also made a turbo line482326_259982610803551_974394119_n.jpg
Edited by turbosubarubrat
  • 2 weeks later...
  • 2 weeks later...
3/16/13
420384_270400776428401_1875693848_n.jpg5346_270400879761724_1366289493_n.jpg3/17/13
541112_270401543094991_352101398_n.jpg292272_270401723094973_2092340120_n.jpg6445_270401806428298_872627176_n.jpg482099_270401929761619_1762307780_n.jpg579135_270402009761611_285705026_n.jpg
3/24/13 where is the u shaped hose supposed to go? i do not think  it is even the right hose but it came with it on it. is it supposed to go to onto the intake monifold where the thermostat is?579995_270402653094880_1637233872_n.jpg
  • 2 weeks later...
Did you install the copper crush washers on the bolts for the water inlets for the turbo? If not they will leak when you do get coolant to it.
yah i did.
  • 1 month later...
Updates... :popcorn:
sometime soon since im out of school next wednesday :banana: hope to figure this hose mess up soon and get the radiator support put on my brat. i went to a wagon for sale identical to this one awhile ago and figured some stuff out.
  • 2 months later...
irorny at its finest im getting her a twin today and its the same one i looked at to figure to try to figure out the hoses :D pics are coming later
  • 2 months later...
Shes back together and all the hoses are right now i made a y connector to tap into the coolant inlet line for the heater core to go to the turbo. The hard line for the coolant inlet i cut off part of it and welded back on to point toward the drivers side of the engine bay. I also adjusted the valve clearance again since the engine still felt to tight. Replaced the fuel pump with one off a ford f-250. Just when i thought she was going to fire up the starter went caput on me even though its a napa reman with stickers still on it from the junkyard. I think a gear or something broke because the starter turns really freely both ways while the two spare manual transmission starters i have only trun one way plus i tested it and nothing. So another trip to the junk yard is in order for tomorrow.
Got her running but idling really high(im guessing like 4000rpm since i dont have a gauge cluster in at the moment), so im a tooth off or some thing on the timing. It turned out why it wasn't running is that it wasn't getting enough compression. It had 50-70psi in each cylinder, so i unpluged the spark plugs wires and started tightening and loosing the clearances on each cylinder until i had about 150psi just by going by what the compession tester said since the filler gauge has been screwing me over with this.
  • 2 weeks later...
She was running ok and i fixed the exaust leak, but im going to put on another cat. because it still leaked so i quess its rusted in the center that is a main reason why it sounds like crap. Im going to put  the new one where it orignally was just below the turbo by the fire wall. I finally traced the coolant leak which turned out to be the weep hole for the water pump after taking off the alternator and pulling the ac condessor with bracket :rolleyes:. Just got the new pump tonight so hopefully tommorrow i will get to drive out of the green house and wash all the dust off of her. The brakes need blead some more before that happens but luckily i didn't need to replace the master cylinder because it turned out just to be a clogged bleader valve on the drivers side rear :). I have a cluster in thats non turbo and it idles about right but dies  hope to solve that too.
  • 2 months later...
Back when i put the f-250 fuel pump on
Turbo plumbed to run oil and coolant a couple months ago
water pump was leaking from weep hole and replaced it a couple months ago with a new one from knects plus some new hoses
shows how long it sat (taken a couple months ago)1962713_415610758574068_1527310011_n.jpg
1797522_415611081907369_710265588_n.jpgRadiator was leaking and the plastic plug broke in half so i rethreaded for a bolt. Cut the bolt down, washed radiator out, and put the bolt on with pipe sealer so it can come off when i need it to.
1939900_415611558573988_1077517370_n.jpg1619098_415611625240648_1674895484_n.jpg1948126_415611791907298_1665208369_n.jpg
