January 16, 201313 yr This is a working AC kit from a 1977 Subaru GL Wagon. I pulled all wiring, hoses and necessary part to add or repair your AC kit. $150.00
February 5, 201313 yr Pooparu, How hard would this be to add to 78 wagon lacking such convenience? Jordan
February 8, 201313 yr Author Pooparu, How hard would this be to add to 78 wagon lacking such convenience? Jordan That depends on your experience. I'd say for someone with good automotive knowledge it wouldn't be too hard, but if you've just got basic automotive skills then it might be kind of a challenge.
February 10, 201313 yr Well, I replaced the transmission and several cosmetic bits in the cabin as well as most of the expendable drivetrain parts, but if it's more of a mechanical, adding mounts, piping coolant and such, then yes I don't have so much experience. I'll have to look into it.
April 6, 201313 yr By chance do you have a close up shot of the compressor ID plate? I'm trying to figure out some of the specs IE: how much of the old R12 refrigerant would it have required. I have an "SD" compressor. Not sure if this is the same style but figured I'd give it a shot. Thanks.
April 9, 201312 yr Does it require certain refrigerant? Would I be able to get it charged? Could be interested if so....
