2002 Subaru Outback - CEL - P0065 P0137 P0138
My CEL came on last week, so I stopped by Advanced Auto today and got the codes read.
It came back with the codes:
P0065 Air assist injector solenoid valve malfunction
P0137 Rear Oxygen Sensor Circuit Low Voltage
P0138 Rear Oxygen Sensor High Voltage
Has anyone dealt with these issues before? Does it make since that these codes would occur with each other?
Where in the heck is the "Air assist injector solenoid valve?"
Any help is greatly appreciated!
Thanks
A head scratcher. Doesn't make much sense to get both high and low voltage codes for the O2 sensor. I would have to guess that's going to be a loose connection, possibly a chafed wire.
Air assist injector I'm not sure about. Would have to look it up in the FSM.
What engine is in the car?
Thanks for the help.
It's the 4 cyl 2.5L
I'd be tempted to do 2 things to begin with;
Clear the codes and monitor how quickly/which ones return.
Inspect for rodent damage to wires/hoses.
Thanks guys. I checked/cleaned all the ground connections and also cleaned the battery terminals/posts. I reset the check engine light and it hasn't came back yet.
nice hit. if you think about it...report back in another month or few if this worked. very interesting.
